Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: July 2017, Beta Release 5
    Default July 2017, Beta Release 5
    Download EFILive V7.5
    Download EFILive V8 (please see Issue #3 below and make sure to update your firmware to V2.07.119 or later)
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFlLive recommends beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFlLive beta test software on a separate PC, laptop or virtual machine.
    Release Notes:
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.10 Build 329 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.5 Build 321 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.118 (Jul 11, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue #1:
    Workaround:
    None.
    Issue #2:
    Workaround:
    Issue #3:
    Some GM controllers can not be licensed when flashing using FlashScan in standalone mode or in pass-thru mode from EFILive V8 (AutoCal is not affected, EFILive V7 is not affected).
    Workaround:
    Update firmware to V2.07.119 (Jul 22) or later - available as an attachment below.
    Issue #4:
    The firmware provided to fix known issue #3 did not have the correct version number compatibility settings for V7 which cause V7 to refuse to connect to devices with that firmware because of version incompatibility.
    Workaround:
    I can no longer flash my LML ecm that's already been licensed with this update. See pic
    Robert
    04 LB7
    2010 LMM
    2015 LML
    Quote Originally Posted by rcr1978 View Post
    Robert
    Check in your VIN licenses that there is a matching entry for the last 9 digits of that serial number, i.e. 418900120
    You can check your VIN licenses in the [F7: Licenses]->[F3: VINs] window.
    If not, send me your license backup file which you can create in that same window by clicking the [Backup] button. Send it to paul@efilive.com, include a link to this thread.
    It's there Paul, thanks for the quick reply. see pic
    04 LB7
    2010 LMM
    2015 LML
    After clicking the [Cal Flash] button and the flash failing with error $0533, could you please locate the *.htx trace file in the folder: \Documents\EFILive\V8\Trace and send me the file, thanks.
    Paul Mail sent, forgot to add link to this thread though.
    04 LB7
    2010 LMM
    2015 LML
    Have you updated your FlashScan with the firmware (that came with beta-5). Click the [Check Firmware] on the main V8 page.
    yes, yesterday before a autocal setup for a LBZ that was successful.
    04 LB7
    2010 LMM
    2015 LML
    I have a different confuzr and a LMM to test on if needed?
    04 LB7
    2010 LMM
    2015 LML
    I can see the problem. It's a fault in the firmware licensing routine. It is incorrectly identifying the LML as a Cummins controller and then failing because there is no Cummins tuning license in your FlashScan. I will update the firmware asap and attach it to the first post of this thread. Check back in about 1/2 hour.
  1. July 2017, Beta Release 4
    Last Post: July 10th, 2017, 03:42 PM
  2. April 2017, Beta Release 2
    Last Post: June 29th, 2017, 03:06 PM
  3. April 2017, Beta Release 1
    Last Post: April 18th, 2017, 02:31 PM
  4. July 2016: EFILive Beta Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: September 5th, 2016, 03:18 PM
  5. EFILive July 18th Beta Release (CSP5)
    By GMPX in forum Software Updates and Installation Help
    Last Post: August 22nd, 2013, 02:18 AM
