Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Need stock file
    Oct 2015
    FYI -
    Controller VIN, OS, Serial number, and for Cummins controllers Calibration ID can now be displayed on FlashScan and AutoCal screens. Users can access this information by connecting their EFILive hardware to their vehicle, and following the below instructions:
    FlashScan: F3: Diagnostics -> F1: Display Info -> F1: Display VIN/Info.
    AutoCal*: Users can navigate through to the following menus
    •Scan Tool->Display VIN
    •Scan Tool->Display OS
    •Scan Tool->Display SN S
    •can Tool->Display Cal ID (for Cummins controllers only)
    * Advanced menu only. You may temporarily activate the Advanced menu by holding down the [Next] button while powering up AutoCal. The Simple menu will revert when the device is next powered up.
    Senior Member Quinton's Avatar
    Apr 2013
    Ok. Main reason I'm
    Looking for the correct OS is because airbag, parking brake, and ABS light is on and has been on since last tunes where put on the truck.
    [/SIGPIC]
    2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
    Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
    Nov 2010
    Quote Originally Posted by Quinton View Post
    Ok. Main reason I'm
    Those issues aren't tied to the wrong OS...someone flashed the incorrect Vin into the ecm at some point
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Apr 2013
    Quote Originally Posted by 2007 5.9 View Post
    I thought cummins won't take a tune with wrong vin? What do I need to do to fix this issue?
    [/SIGPIC]
    Nov 2010
    IIRC if you forget a value or get a letter wrong it'll start but have dash lights...or something to that effect.
    At this point verify the correct Vin is flashed into the ecm, and if the lights stay on then you'll need a dealer tool to reprogram the tipm and abs module with the correct Vin.
    Les Szmidt
    2007 5.9 Dodge Ram
    Apr 2013
    Okay thank you, I'll see what I can do.
    [/SIGPIC]
  1. HELP!! need a 07.5 c.c stock file
    By speedomotive in forum Cummins 6.7L
    Last Post: July 11th, 2013, 02:59 AM
  2. stock tune file?
    By THEFERMANATOR in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 22nd, 2011, 05:54 PM
  3. I need a stock file for
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 8th, 2010, 10:09 AM
  4. looking for a 3.9L stock file!
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: November 1st, 2007, 06:22 PM
  5. I need a stock file
    By FFP in forum E37, E38 & E67 PFI ECM's
    Last Post: July 23rd, 2007, 06:28 AM
