Gentlemen: I am a newbie here but not to EFI. Have a project wherein the 0411 PCM will be used with a Small Block Chev (SBC) in the same manner as S10(EFI connection). The 383 SBC is built and has a 236/242 @.050 camshaft with 1.6 rockers for an honest .600 lift at the valves using solid roller camshaft. With a 650 CFM carb right now on a run-in stand it wants so much fuel that it will not idle below 1500 RPM. Shooting for 500 HP and 500 Ft/Lbs Torque and will be installed in a Datsun 240Z with T56 trans. Have a 2003 Corvette Drive by Wire Throttle Body and 2006 5 wire MAF. Need to get a 24x reluctor wheel from EFI connection and already have Vortec distributor for camshaft sync. Have obtained harness. Need to get this all worked out on the test stand with EFI Live hardware and software.
Need comments as to tune file and installing this Gen III EFI. Thanks.
