Results 1 to 10 of 15
Thread: Known issues with Feb 2015 release of the EFILive software and firmware.
    Default Known issues with Feb 2015 release of the EFILive software and firmware.
    Currently known issues and possible workarounds for the Feb 2015 release of the EFILive V7.5.7.276, V8.2.2.270 software and the V2.07.77 FlashScan and AutoCal firmware.
    Issue 1:
    Workaround:
    None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
    Issue 2:
    The LML calibration segments names are not correct in the EFILive V7.5 Tuning Tool software.
    Workaround:
    None.
    Issue 3:
    The 2013+ CME calibrations may have a labelling error where all the 'Base' and "Alt 1' tables are swapped.
    Workaround:
    None, we are investigating this.
    Issue 4:
    Logging external* PIDs either in BBL or V7.5 pass-through can result in incorrect external data being logged.
    *External PIDs are any PIDs that fall into the following categories:
    • FlashScan V1/V2 analog PIDs (i.e. wide band analog voltage PIDs)
    • Wide band serial PIDs
    • Dyno PIDs
    • FPE PIDs
    Workaround:
    Issue 5:
    The "What's New" document lists the following upgrade:
    A50 – first transmission calibration release for 2009-2010 LML based operating systems.
    It should show:
    A50 – first transmission calibration release for 2009-2010 LMM based operating systems.
    Workaround:
    None.
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    When trying to load E35b LMM files onto an autocal or V2 I get error $0185. I have tried this with several autocals and they will take other file types (LML,6.7, 5.9, etc) but will not take an LMM file.
    On edit: This only happens with files that were saved using the feb software. I can load older LMM tune without issue.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    May 2010
    E92 labels which mentioned in last update still not fixed
    it still show 0.02 as maximum value
    EFILive Tuner
    Quote Originally Posted by anarchydiesel View Post
    Error $0185 is "File or Folder not found".
    To which folder on the FlashScan/AutoCal device are you trying to copy the file?
    Are you definitely trying to copy a real *.ctz file and not a link or some remote/network reference to a real *.ctz file?
    Have you tried reformatting the [Data] file system on the AutoCal device using EFILive Explorer?
    Aee you using and SD Card on with FlashScan? If so yo umay need to reformat the SD Card, do that using FlashScan menu: F4 Options->F2 File System->F3 Format File Sys.
    If you still can't copy a file to FlashScan/AutoCal. plese send me the file (to paul@efilive.com).
    Which E92 operating system, and which calibration(s)?
    Sorry to ask again but its better to repeat all the information in this thread again.
    May 2010
    Quote Originally Posted by blacky View Post
    which e92 operating system, and which calibration(s)?
    paul
    e92 os 12663390
    b0169
    b0170
    EFILive Tuner
    Aug 2010
    Hello Paul,
    Wesam is correct ... B0169 (PE Ramp In) and B0170 (PE Ramp Out) for E92 OS12663390 are not correct in the latest software release. I opened the same calibration with the current software release, and with an older version of the software - the results differed by a magnitude of 100. The allowable range for those parameters use to be displayed as "0.00 to 2.00", and is now displayed as "0.00 to 0.02". The values in the cells also changed by the same magnitude (e.g. 0.05 before, and 0.0005 now).
    Hope this helps ... I didn't check any other parameters.
    Taz
    Jun 2011
    Trying to copy to the "tune" folder on both devices. No sd card in the V2 and no other tune/scan files saved on the V2. I have performed the format all data on the autocals with the same results. Files are definitely original .ctz files. Email on its way.
    423-506-7427
    Dec 2012
    Issue 5:
    It should show:
    Workaround:
    None.
    I think you got your LMM and LMLs switched around again!
    Josh
    '04 GMC LLY
    Fixed now, thanks.
  1. Known issues with Jan 2015 release of the EFILive software and firmware.
    Last Post: February 4th, 2015, 05:55 PM
  2. Known issues with Oct 28, 2014 release of the EFILive software and firmware.
    Last Post: January 27th, 2015, 06:42 PM
  3. Known issues with Jul 07, 2014 release of the EFILive software and firmware.
    Last Post: July 10th, 2014, 09:12 AM
  4. Known issues with Jun 21, 2014 release of the EFILive software and firmware.
    Last Post: July 3rd, 2014, 10:12 AM
  5. Known issues with Nov 07 2013 release of the EFILive software and firmware.
    Last Post: June 14th, 2014, 09:53 AM
