Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Aug 27, 2015: EFILive Public Pre-Release
    Quote Originally Posted by anarchydiesel View Post
    If it makes any difference, the .ctz files that .coz files were created from were saved just using the "save as" option. They were not saved for Autocal so they should not have had any kind of restrictions in place.
    Do you still have the original *.ctz files that have no security settings active? You would need those files if you ever wanted to edit the tunes. If you still ahve them, then using the latest software save them as *.coz files. That will create *.coz files with no security settings. Then when you add the *.coz files to the *.bbx quick setup, you can apply the "Cannot be viewed of Modified" and the "Remote AutoCal" options.
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    The quick setup I sent you should have just that done. I resaved the .ctz to .coz today to see if it would make a difference.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    What I meant was there are 4 *.coz files in the *.bbx quick setup file. Those 4 *.coz files were originally created from 4 *.ctz files, either by explicitly saving them as *.coz files in the V8 tuner software or by conveting them to *.coz files in the BBX quick setup. Those 4 original *.ctz files must have had the "Lock" flag set (called Auto-Lock in the V8 tune software) because the lock flag gets propagated to the *.coz files. Because the original 4 *.ctz files also had the security setting: "Cannot be Viewed or Modified" set they cannot be edited in the V7 software.
    So what I was trying to ask was: do you still have copies of the *.ctz files from before the "Cannot be Viewed or Modified" and "Lock" options were set? If so then just recreate the *.coz files from those *.ctz files that don't have their "Lock" flag set. Then the *.coz files won't have their lock flag set and your users won't get the error.
  1. Known issues with Aug 27, 2015 Public Pre-Release
    Last Post: September 7th, 2015, 12:36 PM
  2. Aug 13, 2015: EFILive Public Pre-Release
    Last Post: August 27th, 2015, 10:14 AM
  3. Known issues with Aug 13, 2015 Public Pre-Release
  4. Aug 07, 2015: EFILive Public Pre-Release
    Last Post: August 12th, 2015, 12:46 PM
  5. Known issues with Aug 07, 2015 Public Pre-Release
    Last Post: August 8th, 2015, 11:42 AM
