Can you try a different USB port on your PC...
I notified Tech Support.
i tried, no avail. thanks.
After it freezes, unplug the V2 - does the software unfreeze? If so, save a trace file (on the [F8: Trace] tab page) and send it to me at paul@efilive.com
yeah, the update doesn't freeze per se, progress bar just stops and $0101 error window pops up. then i have to dead poll start the box to get it recognized. rinse, repeat, same thing. i will try to install the software and update firmware tomorrow on another machine (that one is dual boot W7/XP so i can try both OSs). if that fails i will email a trace. thank you.
firmware update succeeded on the other system (laptop). i wonder why it failed on my PC, it's a new machine and same W7 x64 operating system.
I am having similar issues with my V2. I just updated to the Nov. 7th V8 and V7 release and tried to update firmware and boot block on V2. Now the blue light stays lit and screen reads EfiLive flashscan V2. It will not update
boot block and does not recognize current firmware or boot block. What am I missing? Current Firmware version 2.05.21 Sept. 25 2008 and boot block version 2.05.04 Oct. 16 2007 on V2.
When I unplug usb cable and plug it back in it says Boot block has been upgraded license will be upgraded now, click ok an It then says Upgrade completed successfully.
Did you read thru the pdf in post #1 here: Upgrading-from-older-boottblock-firmware
What firmware/bootblock versions did you have prior to updating...?
What did you do...?
What does V2 do now...?
The firmware/boot block never changed despite saying it was updated. Firmware 2.05.21 and boot block 2.05.04.
I downloaded the latest release of the V8 and V7 software, then attempted to update the boot block. V2 is basically unrecognized now.
