Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 57
Thread: Why does this engine want to idle at 1500RPM
  1. #41
    Mar 2009
    That doesn't look like right. The tab on the throttle body should rest against the set screw and the set screw should be backed down to close the throttle blade more. The bigger blade shouldn't need too many screw on the set screw.
    Is there adjustment in the throttle cable that will allow the throttle blade cam to go all the way back to set screw?
  2. #42
    Aug 2008
    No adjustment but here is the cable off so i know the blade is closed.
  3. #43
    Mar 2009
    Seems like something is keeping the blade cracked. When you remove the cable, the throttle blade cam should rest against the screw from the pressure of the spring.
    Can you move the blade closed by hand so it rests against the screw? Also confirm that where it is now, the blade is actually closed?
  4. #44
    Aug 2008
    Negative as far as being able to move butterfly towards set screw.
  5. #45
    Mar 2009
    The air is not coming from their then. I would focus on the IAC valve and its wiring. Air must be coming from there is not the PCV, EGR, or vacuum leak.
    Let us know how it goes.
  6. #46
    Lifetime Member limited cv8r's Avatar
    May 2005
    The holley tech doc for the holley 90 throttle body shows an idle bleed as in pic attached. Does yours have this? If it does, is it adjusted correctly?
    It's all good until it goes "Bang"
  7. #47
    Aug 2008
    No its a different throttle body. Part number 112-576. No bleed screw
    Sent from electronic life sucking device.
  8. #48
    Quote Originally Posted by sparkinak View Post
    I am kinda confused on the tranny question/comment. When I did the top end of the motor I decided to go thru trans while it was out. The clutches and steels were burnt so I replaced them with reds, replaced the sprags and then checked clearances etc.
    I'm trying to figure out if the tune caused the line pressure to be calculated low (which causes slipping)
    ( basically, in the PCM: low airmass calculation -> low torque calculation -> low line pressure calculation )
  9. #49
    Also try this with engine running: remove the PCV air hose from valve cover to throttle body port, and use your finger to block off the port, what happens...?
  10. #50
    Does it close by itself so that the stop rests against the screw...?
  1. Problem with surging idle and engine dying
    By JoshH in forum Gen III V8 Specific
    Last Post: October 24th, 2016, 02:45 AM
  2. reduced engine power p1514 KOER set at idle but P1518 set KOEO
    By megadeus in forum Gen III V8 Specific
    Last Post: April 11th, 2015, 08:58 AM
  3. Engine stalling at idle in open loop only
    By genR8 in forum Gen III V8 Specific
    Last Post: September 3rd, 2012, 06:44 PM
  4. Engine RPM vs Engine speed
    By SPi in forum Gen III V8 Specific
    Last Post: August 11th, 2011, 03:09 PM
  5. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
