Results 1 to 4 of 4
Thread: AEM X-Series WB took out my Cluster/Aux BCM???
    May 2014
    Default AEM X-Series WB took out my Cluster/Aux BCM???
    Not sure where to post this.
    2012 Vagon.
    Bought and installed the AEM X-series WB with the Canbus OBD port option and as soon as it was plugged in, it took out the cluster. Tech2 shows no comm on cluster and other devices
    Something AEM tech mentioned was that some of these cars have a known issue of active weird when OBD devices are connected and that there
    Oct 2022
    I have the same problem too
    May 2014
    Quote Originally Posted by ViktorY View Post
    Same as in cluster went out or other modules start acting up but reset once the gauge is disconnected?
    May 2014
    So far I got advice to remove fuses 52/60/64 under the hood and also remove battery (not concurrently) and connect terminals together for a LONG time to discharge any capacitors in the system that may hold any charge to do a full reset. Let
  1. The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
    By dr.mike in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2021, 08:09 AM
  2. Aem x series calc pids
    By ksmrz in forum E37, E38 & E67 PFI ECM's
    Last Post: August 28th, 2019, 06:07 AM
  3. AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
    Last Post: July 24th, 2017, 07:58 AM
  4. AEM X-Series Wideband - Serial
    By Gregs in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2017, 07:20 AM
  5. Replies: 4
    Last Post: July 6th, 2008, 03:34 AM
