Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
Thread: Help creating calc.PID's for AEM 30-0300
  1. #21
    Quote Originally Posted by chambiec1 View Post
    And this is how my VE table came out after pasting the values from the calc.vet log.. some of those cells seem extremely high to me
    Attachment 20461
    That is VE in % units... wow, those are large VE's... are you boosted...?
    Maybe when you get the MAF corrected the calculated VE will come down.
    BTW: on the map properties Data tab, checkmark Show Units.
    Questions:
    - is your IFR table B4001 correct for your injectors and rail pressure (which you measured)...?
    - does IFR take into account whether FPR is manifold-referenced (flat) or not (sloped with sqrt)...?
  2. #22
    May 2016
    Questions:
    Not boosted. 2003 Silverado, long tubes, offroad y-pipe, airaid MIT tube, and 218/224 .553 113+3 cam from BTR. Stall converter, built trans, 4.88 gears.
    Injectors are stock. Everything else on the truck is stock.
  3. #23
    May 2016
    I got the MAF values to transfer over... I'll have to double/triple check everything else, and run another log to see what I get for the VE. If it comes up with strange values again, I'll have to track down the problem.
  4. #24
    Post log/tune and calc_pids.txt files.
  5. #25
    May 2016
    Here's the pid's, log, and the current tune on the truck. The current tune is a professional mail order tune, that I've been tweaking on to get it perfect. As we speak, I have just done the RAFPN and RAFIG process once each... have not loaded anything from the calc.VET process onto the truck yet. The log was from attempting the calc.VET.
    RAFPN.ctz
    calc_pids.txt
    calc.vet log.efi
    If you see anything that jumps out at you, by all means let me know. The truck doesn't run bad, just trying to dial in the tune, and work through a few idle quality issues / get the idle sounding a bit better.
    Appreciate the help, Joe.
  6. #26
    RAFPN.ctz
    calc_pids.txt
    calc.vet log.efi
    I'll take a closer look tomorrow.
    Which pid are you using as the BEN pid...? Are you using serial comms...?
  7. #27
    May 2016
    To be honest, I'm not sure I rightfully know. I was logging calc.aem1 ben and that's the factor I used in map B
    And I'm running the WB analog trough A1
  8. #28
    May 2016
    Here's a log I just ran, Joe. Still getting some fairly high values for the VE table. One thing I noticed, is that my LTFT are fairly well positive.. not sure if that could be throwing me off or not.
    But I double and triple checked everything as far as I know in my calc.VET process, and I'm fairly sure I've got everything right.. I'm not sure if I've got a problem in one of my calc.pid's or what..
    calc.vet2.efi
  9. #29
    Ok, I see what happened, you're using your AEM with analog connection, but the Calc.VET tutorial/thread uses serial comms...
    so I modified your calc_pid.txt (see attached) so that CALC.WO2BEN uses CALC.AEM1.BEN, this allows you to follow the Calc.VET tutorial as it is written.
    ( since the CLC's are calculated in order, and now we need CALC.AEM1.BEN before CALC.WO2BEN and CALC.SELBEN, I repositioned the CLC in the text file to make it obvious )
  10. #30
    May 2016
    You're awesome, Joe. I'll run another datalog with the new PID's in the morning and post with what I come up with. I appreciate the help, these calc's can be a little confusing..
  1. calc.pid /sae.generic - pid resoultion question
    By cyipher in forum Gen III V8 Specific
    Last Post: February 6th, 2014, 12:00 PM
  2. AEM UEGO wideband Pid?
    By derkscustomcars in forum External A/D inputs
    Last Post: August 8th, 2011, 01:42 AM
  3. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 10:28 AM
  4. Creating Custom PID, NaN function available??
    By 2002_z28_six_speed in forum General
    Last Post: September 21st, 2007, 01:32 PM
  5. Replies: 8
    Last Post: September 13th, 2007, 07:52 AM
