Results 1 to 10 of 20
Thread: 2017+ Express van 2.8
    Nov 2005
    Default 2017+ Express van 2.8
    Ross, have you looked at any 2017+ diesel Express van cals? They discontinued the 6.6 dmax in the vans for 2017 model year and now use the 2.8 coupled to the 8L90 8-speed.
    The main OS is 55488073.
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Yes, they are quite different to the Colorado and will be a real pain to map so it hasn't happened yet. The code they run is closer to the Opel and Cruze would you believe (which also hasn't been done due to lack of enquiries).
    Nov 2005
    Weird, I wonder why GM did it that way?
    Is the 2.8 Express van ECM locked down like the new Cruze 1.6?
    12.9s @ 108 mph
    When you say locked down I'm not sure what you mean, they are still running just normal E98's with the 5 byte seed/key (but no SHA signatures like E41).
    Jan 2022
    I thought i'd bump this back up rather than start a new topic.
    From the supported vehicles page, it does say that the 2017-2018 vans with the 2.8l babymax are suppoerted.
    I would just like to triple check that,and also see if there is DSP4 support.
    Thanks for the hard work on these.
    Now that the market is crazy due to you know what I see more people coming back to diesel's for economy.
    It seems like the next wave of owners is just now starting to get into these engines in the vans, and also the Colorado/ Canyon's
    Jan 2011
    I'm doing a few here but the last OS that I read can not be edited with Efilve, 24000176 2019 van
    Thanks,
    Matt Derks
    www.derkscustomcars.com
    Jan 2022
    Thanks Matt,
    I have a customer that wants some work done to it.
    I'm guessing it's engine only and the trans module is a locked T87A?
    Do you happen to have a stock file from one you can share?
    Curious to see how different from the colorado's it is, if at all.
    Jan 2011
    I can send it to you but it can only be read or flashed, unless you have another way of looking at it. it can not be opened to be edited in efilive
    send me an email if you want the file, matt (at) derkscustomcars dot com
    Thanks,
    Matt Derks
    Jan 2011
    And i honestly didn't try to read the transmission
    Thanks,
    Matt Derks
    Jan 2011
    I think the reason that GM uses a completely different OS for the vans is that the rest of the van still has '07-14 gm full size truck' electronics. its all the older stuff.
    Thanks,
    Matt Derks
  1. 2004-2005 5.3 Express Van stock file
    By SkinnyPedal in forum Gen III V8 Specific
    Last Post: September 14th, 2013, 12:55 PM
  2. '07 LMM Express Van Commanded vs Actual boost, etc.
    By Jonny Digital in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 28th, 2012, 01:29 PM
  3. Express Van with no PE, how bout that!
    By Wolfie in forum Gen III V8 Specific
    Last Post: May 16th, 2010, 09:28 AM
  4. '03 Express van 6.0L in '00 S10
    By Sherk in forum Gen III V8 Specific
    Last Post: June 5th, 2008, 06:46 PM
  5. Electronic Throttle for 01-02 Express Van Calibration
    By S10Wildside in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2007, 01:06 PM
