Paul,
Has the V2 analog logging error been fixed...?
Paul,
Glad to see things are progressing, eta for PR07? And then maybe a public release after that (barring any major issues)? Or is everything going to stay Pre Release until the V8 Scan tool is done?
I am getting an $050B error if I try to revert my V2 or Autocals back to the latest public release firmware, even after programming a BBX configuration update with the V8 build 203 public release. Anyone else confirm this and can we get a fix - I shipped an Autocal out to a customer yesterday that I had reverted back to the public release firmware not realizing the script error is going to occur unless it is updated to pre-release 06. I tested this as well - I can go back to the pre-release firmware and BBX program it again with pre-release 06 and everything works again.
Brian
Here are some more details I have been able to confirm-
I can update a V2 or Autocal firmware to the pre-release and as long as I have not written a specific BBX configuration , I can then revert the firmware back to the public release and program the BBX configuration using the public release and no $050B error occurs - so the firmware is not the problem, rather something else is not updating properly on the autocal that I can not erase (I tried formatting the data file and that did not help). Once you program a V2 or Autocal with a specific BBX configuration using the pre-release it is impossible to go back to the public firmware/software and re-program it with the same BBX configuration - ie, once you use the pre-release to BBX program tuning for an E78 you can not revert back to the public version and BBX reprogram the E78 cofiguration.
