Results 1 to 10 of 19
Thread: Short/Long Term Fuel Trims...do these look ok?
    Sep 2011
    Default Short/Long Term Fuel Trims...do these look ok?
    Hey all. I've got an issue I'm hoping someone can help me with. I have a 2013 Corvette with the LS7 in it. It was perfectly running before with a Mamba intake, Fast 102 intake (stock throttle body) and Kooks longtube and catless 3" midpipe. I since added a relatively mild cam (cam card attached), the necessary supporting springs/retainers, and a Nick Williams 102mm throttle body. Since then, I can hardly keep this thing running. It's running stock cam gears and I have verified the timing and have pictures to prove it's spot on. I measured pushrod length with the EO/IC method and they were really just a wee bit longer over stock which I can believe due to the mild nature of this cam. I'm ruling out most of the mechanics of the install and am now leaning more towards the tune.
    Here's what I did. I am shooting for a MAF only tune at this point, but I followed the E38 tuning guide to disable DFCO, and closed loop O2 control. The car would start, and idle (kind of), but when I blipped the throttle, the tone would change to indicate it was clearly cutting cylinders, it would stumble and then die. What I found is that it was pretty consistently flooding out cylinders 3, 5, 7 and 4. I tried pulling out a bunch of fuel from the MAF table but that didn't help too much.
    Then, I turned back on the STFT and LTFT adjustments and noticed something I believe is a bit weird...but that's why I'm asking. Right away, it looks like it is trying to pull fuel from bank 1...which I assume to correct the reason plugs 3, 5, and 7 were wet. And it's looking like it is adding fuel to bank 2. Log attached. The car is stationary, idling, and the areas where I apply throttle is a slight roll-on, hold, and release. I checked the intake for leaks, but everything looks and seems tight. No whistling, odd noises, or anything.
    Let me know if this looks "normal" for an idle condition. What strikes me as odd perhaps is that between the banks, there is at times a 15-20% difference in fueling. I had read that you can't believe trims at idle and they really only apply when driving, but that's just what I read. The issue I'm facing is that if I need a big reduction in fuel at one bank versus the other, how do I ever accurately do open loop MAF tuning?
    Any help or thoughts would be appreciated guys.
    Thanks!
    LTFT look off??
    LOG FILE:
    trims.efi
    CAM CARD:
    Are the front NBO2 connectors accidentally swapped bank-to-bank (maybe not)...?
    MAP waveform does not look correct... I would expect idle to be at 65 kPa and to go up as throttle is opened.
    Sep 2011
    Thanks for the response joecar. Are the left and right side sensors different? I know the primary and secondary are different, but I didn't know that there was a left and a right. Let me know if that's the case and I'll definitely swap them to check. I didn't touch them for this cam install though but they were definitely out with the header install. Let me know if I misinterpreted your response. I'm not sure what to say about the MAP reading, but I know what you are saying...and I have no idea how to remedy if there is an issue with that.
    I have a new shorter log attached with a video link as well. I'm not sure if this issue is related or not. This is when the engine is fully warmed up and it seems to run better. When I blip the throttle, revs go up as intended, but when it comes back down to idle, it goes dead lean, the engine shutters and makes all sorts of funny noises, and then the fuel comes back in and it settles to idle set point. I'm not sure how to keep fuel in this area...or if it even needs to be. I played around with B1829 (minimum idle airflow) but that just seems to leave me with a hanging idle condition as I increase, but I still have this shuttering condition as it settles. Let me know if there are other parameters I should peek at...or if anyone wants to see my tune file.
    Here's a screen shot of the issue area and the log file:
Name:	engine coast down issue.jpg
    LOG FILE:
    TSP trims hot start then blip and die with idle airflow changes 8.efi
    I will post a link to the video when it's done uploading and all that jazz. Seems to be taking a while on my slow internet connection...
    Oct 2006
    X2 strange map behaviour.
    The Tremor at AIR
    Sep 2011
    Here is the video link I mentioned. I apologize for the horizontal display mixup. I guess my phone had a different plan than I did. It might be hard to tell the noise I'm referring to. There is some squeaking as well, but the car is about 3" off the ground on a lift so that's just the lift arms rattling around a bit.
    http://www.youtube.com/watch?v=C-gby_ARjDI
    Sep 2011
    Attached is the tune file if anyone feels inclined to take a peek to see what's going on.
    Thanks guys!
    TUNE FILE:
    TSP_with changes_0009.ctz
    Quote Originally Posted by kjlindgr View Post
    Thanks for the response joecar. Are the left and right side sensors different? I know the primary and secondary are different, but I didn't know that there was a left and a right. Let me know if that's the case and I'll definitely swap them to check. I didn't touch them for this cam install though but they were definitely out with the header install. Let me know if I misinterpreted your response. I'm not sure what to say about the MAP reading, but I know what you are saying...and I have no idea how to remedy if there is an issue with that....
    If the front NBO2 connectors are crossed, then the ECM will cross-trim (i.e. left bank trimming from right bank NBO2, and vice-vera) which causes the LTFT's to diverge (but to a greater extent than what your pic shows).
    You changed cam, springs/retainers, and TB...!?
    Sep 2011
    I understand now what you are saying about the connectors. They're tied up in such a way it would be hard to pull them around and crisscross them.
    Yes, I only changed the cam, springs,retainers, pushrods, and throttle body.
    Also log:
    SAE.LAMBDA
    SAE.MAF
    GM.ETCTP
    GM.HO2S11
    GM.HO2S21
  1. Quick question about Long Term Fuel trims
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: June 17th, 2011, 04:35 AM
  2. How to reset long term fuel trims?
    By Hulkss in forum Gen IV V8 Specific
    Last Post: November 8th, 2010, 05:25 AM
  3. Long Term fuel Trims..
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: July 25th, 2009, 04:23 PM
  4. Long term fuel trims issues
    By Kurtomac in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2008, 06:08 AM
  5. Long term fuel trims from the drop down menu...
    By JR_VETTE in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2006, 05:21 AM
