D2905 immediately around zero slip won't make much difference since this is the rate at which TCC pressure is ramped up (i.e. psi per second of ramp up)... if the TCCSLIP happens to be zero (usually is not) when the PCM decides to command TCC lock, then the TCC will lock easily without requiring the ramp up to be faster... but it won't hurt to try it.
