Results 1 to 7 of 7
Thread: E40 PCM shift light output? And fan
    Default E40 PCM shift light output? And fan
    Hope it's the correct section.
    LS2 with E40 PCM (it's in a Mazda rx7) looking thro the options it has a shift light does anyone know what pin this in or does it output thro the BCM (which we don't have) ??
    Is there a patch to gain proper control of normal/aux fans?
    Blair
    Senior Member Chuck L.'s Avatar
    Next door down!.. Gen4
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    It's not an LS1/LS6, so I moved it...
    It's a matter of locating a 2005/6 GTO/HSV engine controls wiring diagram...
    Thanks Joe I have the wiring diag but can't see it so unless anybody else has any idea's we'll be using an rpm switch to turn the air on off.
    What about fan control any inspiration?
    Aug 2010
    Quote Originally Posted by bikealarmblair View Post
    ... LS2 with E40 PCM ... looking thro the options it has a shift light does anyone know what pin this in or does it output thro the BCM (which we don't have) ?? ...
    Shift light (if the ECM is so programmed) is via Serial Data to the IPC.
    ... Is there a patch to gain proper control of normal/aux fans? ...
    There is no operational patch to control the E-Fans via ECT below 192 F. The E-Fans are controlled with respect to ECT, via % PWM in G0901. And similarly in G0902 with respect to A/C pressure.
    Low Fan - C1 (Blue) pin 36.
    High Fan - C1 (Blue) pin 56.
    Regards,
    Taz
    Ah, shift light is done over the serial bus, that explains why the engine controls wiring diagram shows no control.
  1. Replies: 8
    Last Post: December 19th, 2011, 03:29 AM
  2. Can the 1-4 shift light be controlled on the e38s like the 0411 PCM?
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: March 10th, 2011, 01:33 PM
  3. Using the pcm controlled shift light
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2008, 05:56 AM
  4. Can I setup output for elec fan
    By Madspeed in forum Duramax LLY
    Last Post: June 15th, 2008, 06:50 AM
  5. VT Mil Light & Fan
    By saeb in forum EFILive V4
    Last Post: March 11th, 2006, 09:01 PM
