Results 1 to 5 of 5
Thread: Source and target (PID) addresses
    Sep 2014
    Default Source and target (PID) addresses
    Hi,
    I'm new to this OBDII stuff, perhaps someone knowledgeable can help me out.
    I captured a slew of messages and I'm trying to decode 3 of them.
    Source address, Target address
    10, 53 I think 10=PCM or ECM, and 53= engine systems, is this correct? Can anyone give an example of an engine system? actual message: 88 53 10 4 C4 I'm not sure what this message does?
    40, FF No idea what 40 is, I think FF is Network control, but I'm not sure what that means? Actual message: 28 FF 40 06 07 02 0A 88 I'm not sure what this message does?
    60, EB 60 might be related to displays (I think that means instruments) again not sure what this message is about? actual message: AA EB 60 20 C9 00 97
    Can anyone provide any insight?
    Thank you for your help
    Hi Tom,
    The EFILive scantool abstracts the user from the details (the user would not see the low level protocol op codes).
    Based on the messages I presume you are looking at GM VPW messages. If you are scanning the VPW "chatter" messges that are transmitted on the bus by various modules without being requested then sorry I don't have any idea what data they contain. The data will be different for different vehicles and different modules.
    Here's some module ID's based on the messages you posted.
    $10 = PCM (Powertrain Control Module (i.e. ECM & TCM combined)
    $11 = ECM (Engine Control Module)
    $18 = TCM (Transmission Control Module)
    $28 = ABS (Antilock Braking System)
    $40 = BCM (Body Control Module)
    $53 = don't know
    $60 = IPC (Instrument Panel Cluster)
    $88 = don't know
    $AA = don't know
    $EB = don't know
    $F0/$F1 = Off board tool (i.e. scan tool)
    $FE = broadcast to all modules
    Sep 2014
    $53 = don't know
    $88 = don't know
    $AA = don't know
    $EB = don't know
    Paul,
    Thanks, that's helpful, where did you find this information?
    Tom
    Quote Originally Posted by TomStillo View Post
    Paul,
    Tom
    Many, many years of developing scan tool software and many many years testing it on different vehicles with various module configurations...
  1. Online source for ECU's
    By mhburton in forum Vortec V6/V8 Specific
    Last Post: March 20th, 2010, 04:38 PM
  2. Source need for LB7 ECMs
    By MMLMM in forum General (Diesel)
    Last Post: June 29th, 2009, 11:25 AM
  3. what to use for power source??
    By rpmauto in forum General (Petrol, Gas, Ethanol)
    Last Post: April 11th, 2009, 04:00 PM
  4. Bench tuning power source
    By killerbee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2009, 12:33 PM
  5. Power Source for WB02
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: December 18th, 2005, 02:43 AM
