Results 1 to 9 of 9
Thread: May 2021, V8.3.6 Public Release - Update 1
    Default May 2021, V8.3.6 Public Release - Update 1
    Attention:
    WARNING:
    Due to the new security/encryption option in this release, all tune files saved using V7.5.34 or V8.3.5 (or later) of the software or V2.07.169 or V3.00.059 (or later) of the firmware will no longer be compatible with older versions of the V7 or V8 software.
    If you distribute tune files to other users (i.e. your customers), the recipients must be:
    • using version V7.5.34 or V8.3.5 or a later version of the software.
    • using version V2.07.169 or V3.00.059 or a later version of the firmware.
    Full Release Notes:
    Version Numbers:
    • EFILive V7 software: V7.5.35 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.6 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.064 (May 20, 2021).
    • FlashScan/AutoCal V2 Firmware: V2.08.174 (May 20, 2021); Boot Block: V2.08.009 (Feb 27, 2021)
    Download here:
    Known Issues:
    Issue #1:
    Importing JTAG E86B files may result in a Boot Software segment checksum error.
    Workaround:None.
    Don't flash imported files with checksum errors. Don't use the EFILive software to correct checksum errors for the E86B imported files as that does not fix the underlying cause of the checksum error - it just masks the error(s) and causes additional problems.
    We are working on a solution to that problem.
    Regards,
    The EFILive Team
    Member scottcmb's Avatar
    Aug 2011
    Hi,
    in the notification email that i received about this update it said that E98 was now supported in V8 editor. I updated my software and tried to open my E98 file, but still said its not supported yet and have to use V7 for editing.
    Cheers Scotty
    2008 HSV GTS LS3
    Jul 2003
    Nothing wrong with the V7 Editor.
    Your Email address is now officially on Paul's 'spam list' after comments like that
    Jul 2003
    v8 is still king. V7 motor doesnt exist.
    am i unspammed now?
    Nov 2005
    Quote Originally Posted by scottcmb View Post
    Hi,
    Cheers Scotty
    Where are you seeing that information? E98 has NOT been added to the editor. If we've listed that somewhere we need to correct it.
    Cindy
    Aug 2011
    Taken as a screen shot from the email
    Scotty
    2008 HSV GTS LS3
    Dec 2012
    I'm not sure if it was forgotten about.... But AL5 FULL flashing is still missing from V8.
    Josh
    '04 GMC LLY
    When you say "missing" what do you mean?
    It appears to be active in the latest version.
  1. April 2021, V8.3.5 RC 3
    Last Post: April 21st, 2021, 06:27 PM
  2. April 2021, V8.3.5 RC 4
    Last Post: April 20th, 2021, 11:25 AM
  3. April 2021, V8.3.5 RC 2
    Last Post: April 6th, 2021, 07:11 PM
  4. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
  5. April 2015, EFILive Public Release
    Last Post: April 14th, 2015, 09:21 AM
