Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Holden Colorado MY14 Duramax 2.8
    Member scottcmb's Avatar
    Aug 2011
    Default Holden Colorado MY14 Duramax 2.8
    Is there or going to be support for tuning the new MY14 duramax 2.8 diesel and the auto trans that behind it in the new Holden Colorado?
    Cheers Scotty
    2008 HSV GTS LS3
    Cannot get an ECM, not available through Holden spares yet so at this stage no idea.
    Jul 2011
    Well hopefully not too much longer because I would rather tune my own than have a chip
    No idea who even makes the ECM, might be Bosch, Continental, Siemens, might not even be possible to tune them via reflash.
    Jul 2011
    It would be nice to know it's actually possible. Because if not I'll have to look at some alternatives.
    Aug 2011
    I pick up my new MY14 Colorado hopefully at the end of this week.
    Would you like me to get any details off the ECU unit for you Ross, would that be any help to see if its viable?
    Regards Scotty
    2008 HSV GTS LS3
    I've seen a picture of the ECM sticker but there was no brand on it, regardless there is a million things that can determine if it will be possible or not and without an ECM we can't even take the first steps.
    If does appear it is unique to the 2.8L engine, no other GM Diesel uses it.
    Aug 2011
    If you are in Auckland and when im up there I could call in for you to take a closer look at it if ya want
    Regards Scotty
    2008 HSV GTS LS3
    Jul 2011
    I'll upload some picks of mine this arvo too.
    Quote Originally Posted by scottcmb View Post
    Regards Scotty
    Sure, leave us the car for a month or so
    In all seriousness, having a look at the ECM's case still doesn't tell us much, it is what is going on inside that matters, I have some wreckers on the look out for us, someone will write one off sooner or later.
    When the Duramax LML ECM came out we all thought it was a Delphi because it had E38 style connectors on it....nope, it was Bosch inside.
  1. 2.5l Colorado
    By relentless addiction in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 26th, 2012, 09:48 PM
  2. Holden Colorado Common rail
    By The Alchemist in forum Diesel
    Last Post: June 24th, 2012, 10:01 AM
  3. Colorado P12 3.5 tune
    By hondarider552 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 18th, 2012, 11:58 PM
  4. Need 05 colorado 2.8L stock tune
    By blazinblue in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: April 22nd, 2010, 05:40 AM
  5. EFILive on an 05 Chevy Colorado?
    By Blk02Ls1A4 in forum General
    Last Post: August 29th, 2005, 05:21 PM
