Results 1 to 7 of 7
Thread: Auto Stop on GM vehicles
    Jun 2018
    Default Auto Stop on GM vehicles
    Can anyone confirm or deny that I can disable auto stop on the newer Cruze/Malibu/Equinox before I order my EFILive? It would give me an excuse to purchase it earlier than I had planned. Thanks!
    It is not something we add in for every vehicle but it has been added by request (surprisingly not many people want it disabled for good).
    If that is all you want to do then maybe just buying a tune with it disabled would be a cheaper option to consider.
    Nov 2012
    Hi,
    I am looking for this solution, for example in Cruze 1.4T ECU E80, which I attached original. Could you add these tables, GMPX? Please
    E80-GAZ4588-ROGGE.ctz
    I'll take a look today Gabriel and post an updated .calz back in here.
    Gabriel, I just loaded up your file and it looks like the required parameters are already in there to disable this system.
    By setting the temp parameters out of the range the engine will ever be in it should stop it functioning.
    I've also attached the .calz with these parameters in there incase yours doesn't have it.
    Save in to:
    C:\Program Files (x86)\EFILive\V7.5\Calibrations\E80
    Nov 2012
    Very good, GMPX.
    I will test it and I post results.
    Thank you!
    Found this thread and it saved me a lot of head ache. thanks for posting the fix for this. It worked like a charm for my 2016 Cruze E80
    www.EllweinEngines.com
    Personal cars:
    95 impala SS running on an old Speed Pro PCM (Budget 355 LT1)
    Customer cars:
    96 impala SS, LT1-395ci, 4L60E, Stock LT1 PCM
    96 impala SS, LT1-399ci, 4L60E, BP Harness to 0411 PCM and 24x EFI Connection components
    95 impala SS, LT1-395ci, 4L60E, Re-Pinned stock harness to 0411 PCM and 24x EFI Connection components
  1. Auto VE , Auto Maf, PE & Timing Adjustment
    By maalmull in forum Gen III V8 Specific
    Last Post: August 24th, 2017, 11:49 AM
  2. Disable Auto Stop on 2016 Chevy Malibu 1.5L
    By jaydog in forum Petrol / Gas
    Last Post: June 3rd, 2017, 11:38 AM
  3. Any way to stop this warning
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 6th, 2015, 11:00 AM
  4. How do I stop the auto replotting...?
    By joecar in forum General
    Last Post: June 5th, 2005, 07:17 AM
