Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 138
Thread: Sanity check, please...
  1. #111
    Lifetime Member Rich Z's Avatar
    Quote Originally Posted by ddnspider View Post
    hahahah niiiice.
    PS.....I just did some tuning and I recreated your "burp" LOL Coupler popped off but enough air was still going through the MAF to keep it running. On the plus side I saw a nice drop in MAF Hz since I ran more 4" tubing in front of the MAF....maybe there is hope for me yet. Now if I could just keep the couplers together
    One of the guys on my own forum told me that some of the turbo diesel guys he knows will use hairspray when putting couplers together. The hairspray acts as a lubricant while wet, but then dries as an adhesive. Never tried it myself, personally, but thought it was worth mentioning here.
    CorvetteFlorida.com
    2002 Corvette Z06
    427 RHS block built by LME
    STS rear mounted twin turbos
    It nearly died on the operating table, but I'm bringing her back.
  2. #112
    Dec 2010
    That may work? It's an old school dirtbike trick to get hand grips on the handlebars as well.
  3. #113
    Sep 2012
    Yea I've heard of the hairspray trick, just never tried it either. I was a bit impatient to finish tuning so I didnt have any 4" t-bolt clamps handy either, so worm clamps it is until I can get some.
    Anyways, I don't mean to hijack your thread. I have my own thread of misery
  4. #114
    No worries. It's all good....
    CorvetteFlorida.com
    2002 Corvette Z06
  5. #115
    Jul 2005
    It helps to "rough up" the shiny plastic MAF ends, you can even "machine" shallow grooves. It doesn't take much, just needs something to grip onto.peace Hog
  6. #116
    OK, got the coupler in that I was waiting for and got the airbridge back on. Of course, it's been raining here EVERY day and doesn't look like it will break any time soon.
    First thing I need to do is to take a short run without going into boost so I can heat up the plastic airbridge, and then retighten the T-bolt clamps while it is hot to make sure it snugs up.
    Second thing I want to do is to go ahead and bite the bullet and fill up the gas tank with E10. What do I need to change in the tuning for this fuel change?
    I'm aware that B3601 needs to be changed. E10 means an AFR of 14.13 correct?
    What about any of the PE tables?
    Does anything having to do with my wideband need to be changed?
    Anything else?
    Thanks!
    CorvetteFlorida.com
    2002 Corvette Z06
  7. #117
    E10: set B3601 to 14.1-14.2... no other change needed.
    Your wideband AFR now has to be multiplied by (14.1/14.7)... but if you're using Lambda then you don't need to do anything.
    ( Lambda is regardless of a fuel's stoich AFR... at the stoich AFR, Lambda equals unity )
  8. #118
    Sep 2012
    I must be living under a rock. So if you get regular 93 octane pump gas, because it contains some % of Ethanol, you set B3601 to ~14.2 as your stoic point instead of 14.63?
  9. #119
    Jul 2005
    You change the Stoich point in the ECM/PCM anytime you run E10 fuel, premium or not. But most don't worry about it as the OEM's don't, its a small difference, most wouldn't notice the difference. E10 has been in my area since the early 90's and all stoich points in all PCM's are still left at 14.6:1.
  10. #120
    E00 to E15: the PCM can handle it using trims (i.e. you will see large positive LTFTs).
  1. Sanity check of logs
    By stigmundfreud in forum Gen IV V8 Specific
    Last Post: July 5th, 2010, 11:33 AM
  2. Sanity check please
    By Forcefedperformance in forum Gen III V8 Specific
    Last Post: June 9th, 2010, 12:52 PM
  3. sanity check of semil-OL OEM tune
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: October 5th, 2008, 12:05 PM
  4. Sanity Check on Commanded AFR
    Last Post: October 23rd, 2007, 03:34 AM
  5. Sanity check, please?
    By critter in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2007, 02:14 PM
