Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: scan v7.5 messed up
    Nov 2014
    blacky, please help me with this, while i (maybe still) have your attention.
    i spent over a hour of quality time in an attempt to get font size equal. e.g. if i open the pre-existing "ls1" dashboard in dash-c, unfortunately the y-axis fonts have different sizes. the inputs for the four series are different. so after a while i found out that y-axis font sizes depend on:
    - font size you input
    - width of the x-axis (this "auto-shrinks" the size)
    - if split checked
    i nevertheless didnt manage to get them equal.
    first picture: i made all inputs for series 1-4 identical except for split checked for series 4. despite the box showing the size as equal (input is 28), in reality it will be whats on the screen: series 3 and 4 size is larger. what to do about it? second picture: its possible to shrink the size with the y-axis width, but the four elements shrink in a different way, depending on their number of positions. i got series 3 about equal to 1 and 2, but series 4 is larger.
    i was going to attach two printscreens ("first" and "second picture" above) but apparently they are the wrong format (odt) so i cant. maybe the situation is clear anyway, if not i can try and convert them somehow.
    o.k., here they are, sorry, no idea how to do that better.
    Nov 2014
    and, btw, the exercise ended like this (second picture): screen was blocked. when i opened another version of the scan tool it looked like the first picture, screen blocked. so i dont know if i permanetly f.u. the software on this computer or if that is somehow going to normalize. (this is why in my tuning binder the first page sais in red: "do not touch the settings".)
ID:	24323   Click image for larger version.
    Quote Originally Posted by dian View Post
    Like this?
    To achieve that, uncheck the "Auto size" check box for all four series.
    Set the number of digits to 4 for each series (that controls the font size for the value).
    Set the font size to 20 for series 1.
    Click on the [Copy] button to copy the font name and size of 20 to the other three series.
    You will need to make the y axis larger horizontally to accommodate the fixed font size.
    Those errors have nothing to do with the V7.5 setup or configuration.
    Windows keeps a list of system resources that it has to manage on behalf of a program running on the computer. A system resource is a number (a pointer to an object) that uniquely identifies a resource being used by a program. Resources are things like, images, buttons, menus, windows, toolbars etc. If a program creates too many resources that can cause Windows list of resource to fill up - then you see the "Out of system resources" error.
    You can monitor the system resources used by a program using this application: https://learn.microsoft.com/en-us/sy...nloads/procmon
    If, as you use V7.5 those resource numbers keep going up and reach 10,000 then you will get "out of resource" errors.
    I know I've said this before, but I actually recommend using V8 instead of V7.
    V7.5 was designed back when Windows XP was still a thing. It has limitations (and quirks) that have been addressed in the V8 software.
    Actually you can just look in these columns for the resource usage for each program:
    Sorry, that was the wrong link.
    This is the correct link: https://learn.microsoft.com/en-us/sy...ocess-explorer
  1. Replies: 3
    Last Post: June 25th, 2012, 11:43 AM
  2. My V2 lcd is messed up... Been like this since new....
    By cainer70 in forum FlashScan V2
    Last Post: April 1st, 2011, 01:13 PM
  3. What have I messed up - LC-1 problem?
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 24th, 2009, 02:12 AM
  4. Any news on the messed up scaling of H0101 TCM tun
    By harascho in forum Gen IV V8 Specific
    Last Post: January 8th, 2009, 09:05 PM
  5. Help Truck Wont Start - Flash messed up somehow?
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 12:17 PM
