Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Enable Tap UP Tap Down in Engine SWAPs using corvette tcm tune and external switchs
    May 2012
    Default Enable Tap UP Tap Down in Engine SWAPs using corvette tcm tune and external switchs
    Been searching alot about this and couldnt get a concrete or complete info on this. So far i found i need the corvette TCM tune. and i find a diagram.
    The diagram shows 2 paddles, can i reduce the circuite and leave just one button for upshift and other for downshift like in one of the diagrams a atached.
    It shows 3 resistors, 8.25K, 4.42K and 1.5K, do i just ask for a resistor like that? because i seen some resistors are like 1/4W or 1/2W or something like that????
    Lets say i finish the circuit, and wired it, and writed the TCM corvette tune. To activate the TUTD function what is needed? just move the shifter from D one step down?? it will be M mode?
    If anyone can help i will really apreciate it. i have installed some 6L80E and i would like to be able to use the TUTD thanks
Name:	corvette paddle shifter.jpg
ID:	16851   Click image for larger version.
Name:	corvette paddle shifter2.jpg
    I don't know for sure, but 1/4W will probably be more than ok.
    May 2012
    Ill give it a try and if everything works ok ill upload instructions and how to do it from start to finish because i know lot of people wanna know and sometimes people doesnt wanna share the information. thanks everyone
    Thanks for sharing
    Mar 2007
    400ss - thanks so much for continuing to share your 6L80E swaps. I have been trying to follow along as people have shared information regarding these swaps. Could you confirm which year of Corvette OS you are using in the TCM? I've read that people are using the 2009 OS to get the TUTD, but am not sure if any of the 2010+ OS's would also work.
    May 2012
    another info about 6L80E swaps, i recently done 2 5.3L 6L80E, i can confirm that 08 VIN PCM can work perfectly with 07-08-09-10 6L80E model/tunes. if you use a 11 6L80E with a 08 PCm , trans will not activate reverse, or drive.. i think all corvette A6 will enable TUTD on M mode.. the car that im going to try the TUTD function, is a 2001 XJ Cherokee, 5.3L NON VVT and deleted the DOD, it has a 08 VIN/tune so i will try to use a 09-10 corvettte A6 tune
    Mar 2007
    Quote Originally Posted by 400ss View Post
    another info about 6L80E swaps, i recently done 2 5.3L 6L80E, i can confirm that 08 VIN PCM can work perfectly with 07-08-09-10 6L80E model/tunes. if you use a 10 6L80E with a 08 PCm , trans will not activate reverse, or drive.. i think all corvette A6 will enable TUTD on M mode.. the car that im going to try the TUTD function, is a 2001 XJ Cherokee, 5.3L NON VVT and deleted the DOD, it has a 08 VIN/tune so i will try to use a 09-10 corvettte A6 tune
    So a 2008 E38 ECM can work with any 2007 through 2010 6L80E TCM (T43)? The "if you use a 10 6L80E with a 08 PCm, trans will not activate reverse, or drive" statement appears to contradict your results in the previous sentence. Again, thanks for all the sharing you have done with these great swaps!
    May 2012
    Quote Originally Posted by turbo_bu View Post
    Thank you, I corrected , my mystake. im gonna try to explain a litle more why im saying it works.
    Did an egine swap using a 5.3L VVT and DOD, so i used if a remember a 11 E38 and the trans was a 6L80E out of a 13 camaro, i just wired it and it worked fine..
    another one was a 5.3L NO VVT and DOD, so i used a 08 E38, deleted DOD, the trans was a 2011, it didnt show any engine or trans code, but it didnt activate reverse or drive, only way it activated was if i turned on the car on Neutral, then changue it to Reverse and it activated, then changue it to drive and accelerate it a litle and it did activated drive, but if you stay parked it deactivated again, so changue the VIN using TIS to a 2010 and it worked perfectly. i have done other swaps, and i havent any problems using 07-08 E38 tunes with a 10-09-08 TCM tunes.. sorry if i cant explain myself, but i dont speak english very well, sometimes i dont use the correct words or most of the time
    May 2014
    I am running a 2013 Camaro SS LS3/6L80 in my 68 C10 truck. I have a Speartech harness and a ShrifterSix paddle shifter setup. The paddles work great when I'm in M (sport) mode. When I touch on of the paddles it activates the TUTD feature and allows me to paddle shift the transmission. I can even hold the + paddle for 2 seconds and it will take it out of TUTD and and put the tranmission back in sport mode so that the transmission automatically shifts. However, the one feature I haven't been able to get to work is the temporary activation of the paddles in the "D" mode. I know on the 2012+ Camaros/Corvettes, you can press one of the paddle shifters and it will temporarily allow them to work (TUTD) in the D selector position. But, the transmission will eventually go back to shifting the transmission automatically. Any suggestions? Thanks in advance.
    Feb 2015
    Did you ever figure out how to set up the TU/TD resistors?
  1. 2012 Vette 6l80 tune in older trans for faster tap up tap down and rev matching
    By RD in SD in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 24th, 2015, 01:36 PM
  2. TAP Preset
    By L31Sleeper in forum Allison 5 & 6 Speed
    Last Post: April 19th, 2011, 04:14 PM
  3. Tap up/down TCC during shifts?
    By ssvolvo in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 16th, 2011, 11:29 PM
  4. Reset Tap Cells
    By jaydog in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 23rd, 2009, 08:05 PM
  5. Upgrade from auto tap to v2?
    By poolshark021 in forum Purchase and Shipping
    Last Post: May 2nd, 2006, 04:05 PM
