Results 1 to 5 of 5
Thread: October 2020, Release Candidate 3
    Default October 2020, Release Candidate 3
    ATTENTION - Release Candidate Software
    This software contains a new CSP switchable tune operating system for CMF controllers. It is an "early access" feature that is not intended for production use just yet. EFILive is looking for feedback on the performance of the CMF CSP OS. Please do not install the CMF CSP OS on remote vehicles. Only install it on vehicles in your workshop that you can recover easily if the CSP5 OS causes problems.
    For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
    Full Release Notes:
    Version Numbers:
    • EFILive V7 software: V7.5.31 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.055 (Oct 11 2020). Boot block will be updated to V3.00.005.
    • FlashScan/AutoCal V2 Firmware: V2.07.166 (Oct 06, 2020).
    Download here:
    Known Issues for RC3:
    Issue #1
    Comparing Diagnostic Trouble Code (DTCs) between two tune files using the V8 editor produces inaccurate results for some controllers (i.e. Bosch controllers).
    Workaround
    None, will be fixed in RC4.
    Issue #2
    Generating script files and/or running script files that attempt to modify DTCs using the V8 editor produces incorrect results for some controllers (i.e. Bosch controllers).
    Workaround
    Feedback:
    To ask about features, request improvements or to simply provide feedback (positive or negative) on the new V8 editor, please use this thread: https://forum.efilive.com/forumdispl...V8-Tune-Editor
    Regards,
    The EFILive Team
    Hey Paul,
    Looking at this post it appears that 7.5 has not changed since RC1. While it does not happen often, I find myself needing the
    DVT controls to do a T43 Adaptive reset and re-learn for a C6 with a V3 autocal.
    When trying to connect to either E38 or T43 with 7.5 scan, I get the message ERR_NOCABLE/31 and both 7.5 tune and scan won't connect.
    Am I doing something wrong or does 7.5 have no support for ACV3?
    I'm kinda stuck without full scantool DVT support with a bunch of my customers.
    Chuck CoW
    Quote Originally Posted by Chuck CoW View Post
    Hey Paul,
    Chuck CoW
    Hi Chuck,
    Sorry, V7 does not support V3 hardware.
    We are working to get the DVT controls into V8 so it can be used with V3 hardware.
    Hi Chuck,
    Ok, So... only a few hours in the toilet.... :( Thinking I was crazy....
    I'll send the guy an old AutoCal to handle the DVT stuff.
    I'm not sure why the T43 Full flash didn't work the first time using the target OS mod....
    But thankfully it worked tonight so we're a step closer.
    Is the BBX Logging error with the external pids something that you think might be fixed soon?
    I've been distributing the same BBX configs for some time now and while I have not see the problem before
    I imagine I'm due for a few customer service calls this week on that one.
    Thank you!
    Chuck CoW
    It is fixed in this RC3 release, it was discovered in RC2, here: https://forum.efilive.com/showthread...se-Candidate-2
    You need to look at the "Known Issues" section more closely
  1. October 2020, Release Candidate 2
    Last Post: October 6th, 2020, 11:07 PM
  2. September 2020, Release Candidate 1
    Last Post: October 5th, 2020, 01:46 AM
  3. June 2020, Beta Release - Release 3
    By GMPX in forum Software Updates and Installation Help
    Last Post: June 25th, 2020, 06:15 PM
  4. June 2020, Beta Release - Release 2
    Last Post: June 19th, 2020, 01:56 PM
