Results 1 to 5 of 5
Thread: Help Logging oil pressure GM LS2
    Jun 2015
    Default Help Logging oil pressure GM LS2
    Hi All
    Can you please help. Can I log oil pressure on LS2? If so how do I do this?
    Kind Regards
    Carl
    What year/model/vehicle is your PCM from...?
    Jun 2015
    It's for a 2005 Vauxhall Monaro. ECU is an E40.
    Post yorr tune file...
    If it is the same as the 2005 GTO, then here is the wiring schematic:
Name:	2005 Pontiac GTO - EOPS.png
    edit: the EOPS is on PCM connector C2.
  1. RR and oil pressure
    By Harrismarine in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 3rd, 2013, 09:08 PM
  2. Help with logging oil pressure
    Last Post: January 6th, 2011, 11:56 AM
  3. Oil pressure PID
    By odd boy in forum General
    Last Post: October 24th, 2010, 09:17 PM
  4. LB7 Oil Pressure logging
    Last Post: December 7th, 2007, 06:22 AM
  5. Oil Pressure Sensor
    By Wingnut87 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2006, 02:53 AM
