Results 1 to 3 of 3
Thread: E78 - 2011 chev silvy 2500 6.0l gas - no start after calibration edit
    Aug 2018
    Default E78 - 2011 chev silvy 2500 6.0l gas - no start after calibration edit
    E78 - 2011 CHEV SILVY 2500 6.0L 6L90E (12640467) - STOCK FILE.ctz
    I'm having a weird issue.
    When I go to edit the file, the truck won't start.
    It only does it when I edit the Engine Calibration. I've tried just changing other parameters in the file and the truck will start and run without issue. As soon as I change 1 degree in one of the spark tables, or fuel tables, the truck will just not start. Flash the stock file back in, starts up right away!
    Any help would be appreciated!
    Can you also please post up one of the tunes that is causing problems?
    Aug 2018
    TEST 4.ctz
    I have a few trying to make small changes to get it to work if you need to look at another one.
  1. Cant get 100% Throttle -Tuning E78 ECM 2011 GMC 2500 6.0 HD Truck L96 VVT non AFM
    By 496Stingray in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 2nd, 2015, 10:23 AM
  2. Replies: 8
    Last Post: April 24th, 2015, 02:16 AM
  3. Speed limiter setting on E78 PCM - Chevrolet Silverado 2500 HD 2011
    By Treurentner in forum E78, E83, E84 PFI ECM's
    Last Post: October 9th, 2012, 12:46 PM
  4. Speed limiter setting on E78 PCM - Chevrolet Silverado 2500 HD 2011
    By Treurentner in forum E39, E80, E82 & E92 SIDI ECM's
  5. 2009 chev 2500 hd speedo
    By JST in forum E37, E38 & E67 PFI ECM's
    Last Post: August 18th, 2012, 02:34 AM
