Results 1 to 3 of 3
Thread: No PIDS or A/F!!
    Default No PIDS or A/F!!
    I have done the updates, (seemed to all go OK) But now I cant log my air fuel and there is no pids when I select PIDs on the V2??
    Need help ASAP!! Have car sitting on dyno.
    I have
    bootware 2.06.02
    16oct08
    firmware 2.06.05
    28oct08
    Junior Member ItzNota's Avatar
    Oct 2008
    Quote Originally Posted by minytrker View Post
    I have
    bootware 2.06.02
    16oct08
    firmware 2.06.05
    28oct08
    I said this in another post, but click the SUPPORTED box and make sure it is UNchecked. Find your PLX pids and activate them. It should work.
    I had a similar issue and I have a PLX as well.
    May 2007
    Mine is doing the same thing since upgrading last week. Do you plug in v2 while going into pids on the scan tool ? My v2 does not show the afr pid to log while in black box mode.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
  1. BBL Pids???'s
    By GAMEOVER in forum Black Box Logging
    Last Post: March 16th, 2009, 10:37 AM
  2. How to add my PIDS to BBL?
    By DrkPhx in forum FlashScan V2 BB Logging
    Last Post: March 15th, 2009, 11:59 AM
  3. BBL PIDs
    By mr.prick in forum FlashScan V2 BB Logging
    Last Post: July 4th, 2008, 04:26 PM
  4. PIDs
    By nonnieselman in forum General (Petrol, Gas, Ethanol)
    Last Post: May 12th, 2006, 03:47 AM
