Results 21 to 30 of 33
Thread: March 05, 2011 release candidate 2
  1. #21
    Oct 2004
    When I click the left mouse button it literally does nothing. Right clicking brings up the list of controllers to select from. That's the "normal" operation and why it is noted as such on the image placeholders. I've never heard of it being any different which is why I asked about the mouse buttons having been swapped (that gets me on some peoples machines )
    Andrew
    EFILive Crew
  2. #22
    Left clicking will select between engine and transmission, i.e. the green tick will follow the left click.
    Right clicking will select what type of controller you want to use. If you re-select the already selected controller it will un-select it.
  3. #23
    Found a minor spelling error, V8 S&T -> F5: BBX -> F4: Switch. The word "displayed" has the s and i switched around.
  4. #24
    Thanks Erik - fixed in next update.
  5. #25
    Great, I thought it might be a little annoying if I made a whole support ticket for it ha.
    Assume that this version is going to go full public release soon (with some minor tweaks)?
  6. #26
    Yes, very soon.
  7. #27
    Nov 2006
    I think there maybe a bug that causes the LC-1 to switch to custom AFR setting when using BBL.
    I have noticed it twice after using BBL and w/passthru it would show proper AFR.
    LC-1 WBO2
  8. #28
    Mike, can you give more detail, do you have a log file...?
  9. #29
    Nov 2006
    I've had to reset the AFR value twice.
    Each time it was set to custom.
    Here's a log with the "stock" serial AFR pid. PM.efi
    LC-1 WBO2
  10. #30
    Official public release is now available:
    http://forum.efilive.com/showthread....580#post140580
  1. February 26th 2011 release candidate 1
    Last Post: March 4th, 2011, 09:55 AM
  2. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
