Originally Posted by
Goldfinger911
Hmmm.. Someone else might want to chime in with regards to timing. I know I run a lot more timing in my forged stroker, even on pump gas, but I am at 11.75:1 compression. I would think you could at least run 23 degrees safely on pump. Have you dyno'ed it?
The idle timing is an easy fix with some of the idle spark tables. I didnt see any Wideband AFR in the log, only commanded... did I just miss it?
What are you seeing when you run the truck? Bogging? stumbling, or is everything fine and youre just looking for advice.
You might want to post your tune so some of the experts can look at it. There are some really good guys (and girls) on this forum that have good eyes for that.
