Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Getting a good solid shift in sport mode 6L80e
    i dont think it's really worth it, there is nothing on there that isnt discussed or readily available either here or on the hpt forum.
    seems to me as a quicker way for the guy to get money for offering help with tunes...
    May 2015
    Yes well tre after trolling the forum I have settled with your settings for shift times etc, how about torque converters do you have any knowledge on settings for them? I am trying to put together a basic tutorial with all the information I have gathered so people can find it all in the one spot.
    Feb 2016
    Would you say that site has been useful to you...?
    If you were to rate it, how many stars would you give it...?
    I'm wondering about joining...
    More than anything it's just a place with all the information in one place, and exclusive information that applies to the 6L series of transmissions, so you don't have to sort through any other stuff. Probably no key stuff that you can't find on HPT or EFI forums - it's just in one place.
    Whether it's worth it - honestly I'm not sure. Compared to the literal tens of thousands of dollars I've spent modifying this car (performance and otherwise), $100 isn't a huge deal.
    Quite frankly, I've spent a considerable amount of time and money having "pros" tune this car and I've seen the best performance/feel from using the stock settings out of a 2014 Corvette C7A6 (my father's car). The settings in that tune are substantially more aggressive than the stock C6 settings, and actually quite a bit more than most aftermarket tuners do, while the transmissions themselves are 99% the same (besides the converters). The shifting will never be quite as good because the C6 doesn't have direct injection and therefore cannot precisely control torque output nearly as well as the LT1 in the C7, but still the best shifts I have had in my car. I'm sure there's a good deal of improvement to be had even with the C7 settings, but I've been quite satisfied.
    Applying the 2014 settings to the 2013 and prior does require some interpolation of the data, which I have already done. I'll attach my tune here.NJE_HPT_22_test_TCC_off_C7 _presets.ctz Ignore the fact that the TCC is set to be unlocked all the time (and indeed ALL the converter related settings) - that problem will hopefully be resolved in not too long. Shift points are also a very subjective thing so set those as you prefer. What's key is times, pressures, presets, torque management, etc. TM can honestly be turned down a bit to suit personal preference, but I will take a slower shift that is smoother any day simply because I put 20,000mi/year on this car. If I go to the strip I will turn down the TM settings considerably, but I don't care about minimizing shift speed in town at the expense of clutch material.
    Let me know what you think.
    May 2015
    Cheers mate I will have a look over it and give it a try.
    Thanks for the info.
    May 2015
    Has anyone started playing with the new inertia tables in the beta release? I am going to look at these over the weekend and see what I can find. Any direction I should head would be helpful don't want to wreck the box. Have put all the C7 shift times, speeds pressures etc into my Trans tube but yet to old it into my test car and try it out.
    Aug 2009
    Quote Originally Posted by jmsmotorsport View Post
    Yes , seems to be noticeable on some operating systems but not so on others.
    Either way I cannot seem to datalog any combination of pids to show any changes when making adjustments to these inertia tables
    May 2015
    Quote Originally Posted by APS Luis View Post
    With these tables did you increase or decrease them? I'm guessing you increase but knowing how easy it is to stuff them up didn't want to just guess.
  9. #19
    Aug 2009
    Increased & decreased, tried the "subtle" approach & the "wild" approach with no difference
  10. #20
    May 2015
    Ok so there not very helpful tables at all.
  1. Revision, 6l80e will not rev past 5k in gear, no up-shift at wot.
    By undergroundak in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 19th, 2024, 06:32 AM
  2. swapping Camaro 6l80e to Vette 6l80e
    By secrt007agt in forum General
    Last Post: January 31st, 2016, 04:43 AM
  3. No Shift time adjustment in new 6L80E OS? Adjusting shift times in Torque Model
    By Protec in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 13th, 2013, 10:34 AM
  4. 6l80e shift time completion
    By b18cls1 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 14th, 2010, 02:58 PM
  5. Solid Motor mounts setting off KR
    By NASABlue in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 04:25 PM
