Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Boot Pin Location
    Lifetime Member Road's Avatar
    Feb 2015
    Default Boot Pin Location
    Anyone know or willing to share where the boot pin is located on the 15+ E86b ecm is so it can be read out with Ktag? I have contacted my Alientech rep and he don't seem to know either. Thanks
    Nov 2005
    As far as I know, Ktag doesnt support the E86b (slightly different/newer TC1797 processor)
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Feb 2015
    Alientech said they are working on the seed and they will have it supported. How are the 86b stock file being imported?
    Dec 2015
    Debatebly legal means...
    But I think it's a moot arguement. What's the difference between jtaging out some memory versus just taking it directly from GM? It's kind of like copying a CD versus filming it with a camera.
    As you all know we have the Alientech import option for the E86A (the three memory chunks), not sure why the E86B isn't supported by them but when it is we will be able to do the import of those as well.
    Feb 2015
    Care to elaborate how the stock files are created and imported currently?
    It is an option in V8 under F8:Tools.
    Just point to the three files Alientech reads (MPC, FLS and EPR) load them in and done, you can save it as a .ctz then. Of course make sure the three files are from the same ECM!
    Feb 2015
    Yes I have been using that feature for the 86A but Ktag doesn't support 86B. I would like to know how the 86B file (MPC, FLS and EPR) are being acquired being Ktag don't support it?
    Dec 2015
    Quote Originally Posted by Road View Post
    People get cache files I am guessing from the GM flashing software. Probably in %appdata% somewhere under the name of the tool. Maybe %temp% or the program directory. Not sure how it works, I dont own any of their overpriced junk. They're not encrypted (this will probably change at some point, but who knows).
    Feb 2015
    Quote Originally Posted by Snipesy View Post
    How ever it is done it is not being shared. There is probably a good reason for not sharing too....
  1. E80 L4 sidi flex fuel pin location 2016 camaro
    By david imgrund in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 10th, 2017, 02:46 AM
  2. not sure If in right location .
    By 1stock07 in forum Petrol / Gas
    Last Post: March 12th, 2015, 07:36 AM
  3. COS5 N20 PCM pin location??
    By way2much_01 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 21st, 2011, 12:01 PM
  4. location
    By larshep in forum Gen III V8 Specific
    Last Post: November 11th, 2007, 04:05 AM
  5. shift patterns with pin 71 and pin 31 questions
    By Jdperk-86elco in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 23rd, 2006, 03:20 PM
