Page 12 of 18 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 171
Thread: Installing the V8 Software
  1. #111
    Mar 2008
    Greatly appreciate this and will give it a try.
  2. #112
    Mar 2008
    I tried clicking on status and states, warning flashscan v2 not in dead poll mode
  3. #113
    Quote Originally Posted by 97power View Post
    To put FlashSCan in dead-poll mode, hold down the [Ctrl] button on FlashScan's keypad while connecting the USB cable (i.e. while powering it up). You can tell it is in dead-poll mode when the two orange LED's flash alternately.
  4. #114
    Mar 2008
    Thank you so much Blacky. Everything worked great and was able to flash a computer. Again I appreciate you taking the time to explain it even though instructions are good I just realized when you walked me through it, everything started to click in my head. Great support!
  5. #115
    Sep 2007
    My flashScan will not work either. It is showing firmware version 2.05.21 It is also showing Boot Block version 2.05.04 and its showing I need to upgrade to 2.07.07 but will not upgrade
    I can only get it to show this if I hook it up in dead poll mode otherwise it will just show it is not connected or responding.
  6. #116
    Sep 2007
    I also have no F4 under licensing to upgrade Boot-block.
  7. #117
    Quote Originally Posted by Tecks View Post
    You may need to follow the "recovery" options explained in the document:
    \Program Files\EFILive\V8\Firmware\EFILiveRecovery\ReadMe.t xt
  8. #118
    Sep 2007
    Thank you, I now have 2.07.64 for firmwire and 2.07.07 boot block and shows to be working
  9. #119
    Dec 2006
    I guess there is no need to Register the V8 software? I just got a new laptop and I don't see anywhere in V8 to input Serial, Key, and Issued Date. My V7 is already registered.
    8.7 @ 84 (1/8 mile) bolt-ons
  10. #120
    Quote Originally Posted by Boost View Post
    That is correct. Registration won't be necessary until the V8 Tune Tool editor is released. And even then it may end up not being required.
  1. Installing the V7.5 Software
    Last Post: February 9th, 2021, 11:28 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
