Page 1 of 26 12311 ... LastLast
Results 1 to 10 of 253
Thread: Flashscan data logging..
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Default Flashscan data logging..
    I was told that it couldnt be done with the version I have, 7.5. Now I hear that its possible with the 8.1 version, im sure there are steps I have to take to upgrade. Is there a link to what steps need to be performed so I can do this?
    I had a hell of a time making it work when I bought EFIlive due to Vista. I have never logged a run at the drag strip due to getting caught evertime with my lap top in my seat.. So, let me know if this is doable, Thanks.
    Mar 2008
    I found this.. Still same for Vista?
    http://forum.efilive.com/showthread.php?t=8426
    For Vista, you must be the Administrator (all privileges).
    First install both V7.5 and V8.1 from www.efilive.com/downloads.
    Then upgrade your V2 firmware to 2.04.72 from C:\Program Files\EFILive\V7.5.
    Then read the readme.txt from C:\Program Files\EFILive\V8.1\...
    Be sure to fully understand this readme.txt first before proceeding.
    Be aware of this (you shouldn't have this trouble): showthread.php?t=8834
    Mar 2008
    I dont see why I shouldnt be, its my lap top. lol
    Do I have to install the 7.5 if I all ready have it?
    I can all ready tell I am going to screw this up. Is that suppose to be a clickable links?
    If you dont have the lastest build of 7.5.4.66 (actually .67, but dont worry about that one) installed then you need to download it again (or run the EFILive updater program).
    Nope, those arent clickable. The first one is just the main page downloads section and the others are locations on your HD.
    And even on my personal laptop running Vista Ultimate x64 as the only Admin I had to change the permissions, so double check that one.
    Mar 2008
    Mine says 7.5.3 (build 36).. So, ill start with that and update it.
    Mar 2008
    OK.. everything went good. Updated to the 7.5.4.66
    Quote Originally Posted by waterbug1999 View Post
    Ok, now from C:\Program Files\EFILive\V7.5 flash firmware 2.04.72 into your V2.
    Then when you finished that, install V8.1 onto your PC.
    Then, re-read the readme.txt under C:\Program Files\EFILive\V8.1.
    Mar 2008
    What do you mean?? Here is where I am at.. I have the V2 scan tool plugged into the port.
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
