Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: Question about hooking up AEM gauge output to V2
  1. #31
    Aug 2007
    Which AEM do you have...?
    Does your user manual show and equation relating V and AFR...?
    Or a table of voltages and AFR...?
    I have the aem failsafe gauge as well. That is why I piggy backed this thread instead of creating my own. Sorry for that now, it got long...
    https://forum.efilive.com/showthread...103#post210103
    Here is a thread that lists the calc_pids I used to use...
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
  2. #32
    Aug 2007
    Got home looking at things and found ad1 is 4.40 volts on the V2 and ad4 is at 4.46 volts . My multimeter is reading e
    4.47 volts across the orange connector.
    Side note, I have a "required configuration not found" message that flashes momentary on my V2 when I first plug it in the vehicle.
  3. #33
    Quote Originally Posted by Slowrc View Post
    Post a screenshot of this.
    Also, post here the previous calc_pids.txt that produced the correct wideband AFR for you... I'll edit it to include the BEN calculation
    ( looks like the various AEM widebands/guages are configured differently )
  4. #34
    Aug 2007
    It is a quick 2 second message that flashes on the led screen of the V2 when I first plug it to the DLC of the vehicle. Just don't remember that ever happening. Bot sure how to screen shot that.
    I am looking for the old data on the aem set up I have been using. Thanks again!
  5. #35
    Aug 2007
    Here is the file Blacky posted that I believe I was using. I can't verify because that laptop is long gone.
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    *UNITS
    #Code System Abbr Description
    None None "" "No units"
    K Metric "K" "Degrees Kelvin"
    R Imperial "R" "Degrees Rankine"
    LAM None "LAM" "Lambda"
    EQR None "EQR" "Equivalence Ratio"
    E00 None "E00" "AFR based on E00"
    E10 None "E10" "AFR based on E10"
    E85 None "E85" "AFR based on E85"
    # Add slot definitions here
    *CLC-00-032
    factor 0 4 .0 "{GM.EQIVRATIO}=1"
    *CLC-00-100
    LAM 0.5 1.5 .4 "{EXT.AD1}*0.1625+0.49875"
    EQR 0.5 1.5 .4 "1/{CALC.WIDEBAND.LAM}"
    E00 0.5 1.5 .4 "{CALC.WIDEBAND.LAM}*14.6"
    E10 0.5 1.5 .4 "{CALC.WIDEBAND.LAM}*14.2"
    E85 0.5 1.5 .4 "{CALC.WIDEBAND.LAM}*9.7"
    *CLC-00-110
    factor 0.5 1.5 .4 "{GM.EQIVRATIO}*{CALC.WIDEBAND.LAM}"
    *CLC-00-120
    factor 0.5 1.5 .4 "({SAE.LONGFT1}+{SAE.LONGFT2})/200+1"
    *CLC-00-220
    factor 0.5 1.5 .4 "iff({CALC.CL}, {CALC.LTFTBEN}, {CALC.WO2BEN})"
    *CLC-00-273
    C 0.0 100.0 .1 "{GM.DYNAIRTMP_DMA.C}"
    F 40.0 220.0 .1 "{GM.DYNAIRTMP_DMA.F}"
    K 280.0 380.0 .1 "{GM.DYNAIRTMP_DMA.C}+273.15"
    R 500.0 680.0 .1 "{GM.DYNAIRTMP_DMA.F}+459.67"
    *CLC-00-300
    % 0.0 100.0 .2 "{SAE.MAF.gps}*{CALC.DAT.K}/{SAE.MAP.kPa}/{SAE.RPM}*3445.2/displacement()"
    VE 0.0 2.468 .4 "{SAE.MAF.gps}*{CALC.DAT.K}/{SAE.MAP.kPa}/{SAE.RPM}*15"
    *CLC-00-305
    % 0.0 100.0 .2 "{CALC.SELBEN}*{CALC.VEN.%}"
    VE 0.0 2.468 .4 "{CALC.SELBEN}*{CALC.VEN.VE}"
    *CLC-00-310
    gps 0.0 400.0 .1 "{GM.VETABLE_DMA.VE}/{CALC.DAT.K}*{SAE.MAP.kPa}*{SAE.RPM}/15"
    *CLC-00-315
    gps 0.0 400.0 .1 "{CALC.SELBEN}*{CALC.MAFN.gps}"
    *CLC-00-430
    VE 0.0 4.0 .4 "{GM.DYNCYLAIR_DMA}*{CALC.DAT.K}/{SAE.MAP.kPa}"
    *CLC-00-435
    gcyl 0.0 1.0 .4 "{GM.VETABLE_DMA.VE}/{CALC.DAT.K}*{SAE.MAP.kPa}"
    CALC.CL F032 CLC-00-032 factor Tuning "Closed Loop (based on EQIVRATIO)"
    CALC.WIDEBAND F100 CLC-00-100 "LAM,EQR,E00,E10,E85" Tuning "Wideband measured fueling"
    CALC.WO2BEN F110 CLC-00-110 factor Tuning "BEN from WB"
    CALC.LTFTBEN F120 CLC-00-120 factor Tuning "BEN from LTFT"
    CALC.SELBEN F220 CLC-00-220 factor Tuning "BEN selected from LTFT or WB"
    CALC.DAT F273 CLC-00-273 "C,F,K,R" Tuning "Dynamic Air Temperature"
    CALC.VEN F300 CLC-00-300 "%,VE" Tuning "Calculated VE, not corrected"
    CALC.VET F305 CLC-00-305 "%,VE" Tuning "Calculated VE, BEN corrected"
    CALC.MAFN F310 CLC-00-310 gps Tuning "Calculated MAF, not corrected"
    CALC.MAFT F315 CLC-00-315 gps Tuning "Calculated MAF, BEN corrected"
    CALC.VEDCA F430 CLC-00-430 VE Tuning "Calculated VE (from DCA)"
    CALC.DCAVE F435 CLC-00-435 gcyl Tuning "Calculated DCA (from VE)"
  6. #36
    Aug 2007
    I logged it on the way in this morning and it is further off than I thought . The gauge itself was reading about 14.3to1 AFR and the efilive reading was about 16to1 AFR. Also all the analog inputs read closer to what the meter said than ad1.
    AD1 4.40
    AD2 4.45
    AD3 4.45
    AD4 4.46
    Looks like I should swap over to ad4 as it seems to be the most correct.
    Thanks for all your efforts JOECAR . Thanks a lot man!
  7. #37
    Ok, from looking at your calc_pids.txt, you can use CALC.WO2BEN as the BEN correction factor.
    Question: when your gauge matches the EFILive reading, which calc_pids.txt is being used (post it here).
  8. #38
    Aug 2007
    I don't currently have a set of calc_pids txt that is working to get the efilive reading to coordinate accurate to the aem gauge reading. The data I posted in post #35 is the old one I used a while back I believe. I haven't tried those with the new updates and new laptop.
  9. #39
    Aug 2007
    Btw , I am OLSD tuning always.
  10. #40
    ok, which exact AEM model do you have...?
  1. AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
    Last Post: July 24th, 2017, 07:58 AM
  2. Aem failsafe gauge not serial
    By Slowrc in forum General
    Last Post: August 12th, 2014, 11:23 AM
  3. Question on Hooking LC1 up on 02 Camaro
    By gpr in forum Gen III V8 Specific
    Last Post: July 10th, 2012, 07:33 AM
  4. 98 to 99 Fuel Segment swap gauge output table
    By AutomagicLS1 in forum Gen III V8 Specific
    Last Post: September 27th, 2011, 09:29 AM
  5. AEM Gauge type 6 in 1 WB UEGO controller
    By JET LEE in forum Gen III V8 Specific
    Last Post: January 25th, 2007, 08:25 AM
