Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Update: Aug 24, 2013
    Default Update: Aug 24, 2013
    EFILive encourages customers to use this public update in their production environments.
    Download here:
    Updates:
    V7
    • Fixed V1 not working correctly with the V7.5 software.
    • Fixed DTCs not being displayed by the V7.5 Scan Tool software.
    • Fixed memory leak in the "run script" function
    V8
    • Fixed EFILive Control Panel (aka EFILive_HAPI.exe) so that when Windows is shutdown, the control panel software will terminate without preventing Windows from shutting down.
    • Updated custom unit definitions so that they can now be applied to sub PIDs. Fro example the PID WO2S11 has two sub PIDs: EQ_RAT11 and WO2S11V. Those sub PIDs can now have custom units defined for Black Box Logging and Scan Tool display.
    • Added a Ctrl+F2 hot key option to enable/disable mouse control of the chart inspector.
    • Fixed problem that caused some "signed" PIDs to be displayed using an "unsigned" format.
    • Changed display units of all "Fuel Air Equivalence Ratio" PIDs from "EQR" to "Lambda". Fuel Air Equivalence Ratio" is the same as lambda, "Air Fuel Equivalence Ratio" is the inverse of lambda. Note: The EFILive V7.5 Tuning Tool software uses EQRatio to mean "Air Fuel Equivalence Ratio". The change to the PID units was to standardize terminology.
    Firmware
    • No significant changes.
    Known Issues:
    Please post issues, questions, clarifications (large or small) in this thread.
    As issues are reported and confirmed they will be re-posted as "Known Issues" below.
    • No known issues.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 241
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 234
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.06 (Jul 31, 2013
    To view the installed version, Select F7: Licenses (in the V8 Scan and Tune software).
    Firmware: V2.07.49 (Aug 02
    , 2013)
    Dec 2006
    Installed
    Thank you for the great work
    2007 LBZ 2011 LML Silverado Pickups
    2015 GMC Denali 3500 Dually Diesel Pickup
    2007 Dodge 6.7 Pickup
    Mar 2009
    Will this update fix the issue I've had where if I power up my laptop with the V2 connected it won't freeze? I've never reported it in the past as it wasn't an issue so long as I didn't plug my V2 in until windows was started. And is there any ETA until the extra lockup parameters may be added for the ALLISON TCM to allow lockup with higher torque converter slippage?
    Paul, thanks for the update.
    Quote Originally Posted by THEFERMANATOR View Post
    Yes, it fixes the hanging issue.
    I don't know the ETA of the calibrations that you are referring to.
    Apr 2008
    most of the time I can't read DTC.....
    Last edited by odd boy; August 29th, 2013 at 01:53 AM. Reason: I added 't to can... bug difference hhhhh
    Regards,
    Odd Boy
    Quote Originally Posted by odd boy View Post
    What error message do you get?
    How are you trying to read the DTCs?
    - Using the V7.5 pass-thru software, (please generate a "File->Generate error report"after attempting to read DTCs)
    - Using the FlashScan V2 in standalone mode, (please save a trace file on FlashScan after attempting to read DTCs and before powering off).
    Send files to me at paul@efilive.com with a link to this thread so I know what the files are for.
    Also include the code for any DTCs that you expect to be shown but are not shown - if you know what they are.
    Apr 2008
    I will do that for you on Saturday, I will try both ways....
    Regards,
    Odd Boy
    Sep 2003
    I just downloaded V7.5.7.242 and when I open a .ctz file in the Tune Tool, I get an error message about 'Unrecognized PCM'. This happened for LS1-A, LS1-B and a 2010 Cadillac tune ( I don't know what PCM it uses ).
    I went back to build 241 and everything is okay.
    I tried to flash (2) E38'S with V7.5 and they failed each time, they flashed fine with V8.
  1. Update: Aug 06, 2013
    Last Post: August 29th, 2013, 11:32 AM
  2. Update: June 06, 2013
    Last Post: August 4th, 2013, 08:24 AM
  3. Update: May 25, 2013
    Last Post: June 11th, 2013, 04:28 PM
  4. Update: May 20, 2013
    Last Post: May 24th, 2013, 03:25 PM
  5. Update: May 15, 2013
    Last Post: May 22nd, 2013, 06:01 AM
