Results 21 to 30 of 31
Thread: What are some things that could cause my truck to not go into open loop?
  1. #21
    ok, I'll look at your new logs shortly...
  2. #22
    I see in your log that WO2LAM1 goes rich during WOT...
    but I don't understand what EQIVRATIO is doing...!? And I see AFR matching/following EQIVRATIO.
  3. #23
    Set B3643, 44, 45 to these values respectively: 1.00, 0.006250, 0.006250.
  4. #24
    Member sixltrbtr's Avatar
    Jun 2009
    Yeah, although I don't really understand what that pid is I was expecting it to do something different with the added fuel. Is it like the pcm's desired lambda or something?
    Okay, I will
  5. #25
    Jun 2009
    Ahh yes, I had messed with those. I will re-do the log now.
  6. #26
    Jun 2009
    Does this look better? Still heard a little knock and looks like a lot more fuel than before. Maybe a little too rich in some places.
  7. #27
    Aug 2013
    Zero all values in {B5908} Fuel Mixture Spark Correction.
  8. #28
    Quote Originally Posted by statesman View Post
    I don't remember if B5908 adds or subtracts from sparkadv.
  9. #29
    Quote Originally Posted by sixltrbtr View Post
    Looks much better...
    where it's too rich: you can now edit B3618 PE table to reduce some of that fueling.
    where it knocks: bring B3618 up a little (try EQR 1.175).
  10. #30
    Jun 2009
    Thanks joecar! I will mess with it some more on Monday. After driving the truck around a little bit I can say that it already feels much better and seems to run stronger. I'm looking forward to tweaking the PE fueling to get it dialed in. I have noticed that it likes to knock while the truck is downshifting from a cruise. It feels like it's sruggeling to downshift quick enough or something. I'm wondering if adjusting it to downshift a little earlier would help some of that.
  1. E38 Open Loop VS Closed Loop - strange issue
    By BLK02WS6 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 11th, 2016, 12:47 PM
  2. Replies: 1
    Last Post: April 11th, 2013, 04:28 PM
  3. Open loop or semi open loop still?
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2007, 03:46 AM
  4. Semi-Open Loop Vs Just Open Loop
    By BowlingSS in forum Custom Operating Systems
    Last Post: April 14th, 2006, 05:25 AM
  5. Truck wont idle during open loop speed density
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 23rd, 2006, 06:43 AM
Tags for this Thread
