Results 1 to 3 of 3
Thread: P0106 Code and surge.
    Jan 2016
    Default P0106 Code and surge.
    Ok so I'll attach a data log where I got the truck to mess up but it is throwing a P0106 Code and then if you look at frames 13 and 1409 you will see the surge but it pulls fuel almost like a limp for a split second then is completely fine. Any help?? It only happens when that code is present. If I clear the code it stays away for a few miles and is fine but then all the sudden throws the code and starts doing this.
    Thanks in advance.Surge.efi
    Do you have a diagnostic chart for P0106 for your vehicle...?
    Jan 2016
    I do, I'll go through it tomorrow
  1. P0068 P0106 sets at idle only COS3 STFT enable SD
    By megadeus in forum Gen III V8 Specific
    Last Post: May 16th, 2015, 05:18 AM
  2. Replies: 11
    Last Post: August 25th, 2013, 01:54 AM
  3. P0106 nightmare
    By 02CCSB in forum Cummins 6.7L
    Last Post: December 3rd, 2012, 05:49 PM
  4. P0106 map
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: January 25th, 2010, 04:01 PM
  5. Help P0106 & P0101
    By Moonder in forum General (Petrol, Gas, Ethanol)
    Last Post: December 21st, 2009, 11:32 PM
