Results 21 to 30 of 33
Thread: Man (PCM) Down
  1. #21
    Member Big D's Avatar
    Aug 2007
    update:
    dealer said ECM is dead, they want $400 for a used and $800 for new. Will be buying one from another source. I will keep the "dead" ECM and see what I can do on the bench with it.
    Making tires smoke since 1994
    Grand Junction CO
  2. #22
    Quote Originally Posted by Big D View Post
    update:
    Interesting, havent heard of EFILive bricking any P10s before. Doesnt mean is hasnt happened, but no one has complained about it. Heck, eBay sells P10s for CHEAP, I grabbed one from a wrecked 03 Voy for $40 shipped I think.
  3. #23
    Aug 2007
    Well I think the dealer may not be completely up to speed with type of issues. I dont believe the PCM is a brick. Come to find out the TB has remote start. This gets more interesting by the day. Not sure if the remote start would cause this, like I said earlier never had trouble before.
    Ebay P10 here I come.
    Grand Junction CO
  4. #24
    Aug 2010
    Those PCMs go for $40 to $60 at my local auto recycler ... don't know if prices are different in your area ... saves the wait and the eBay shipping !
    Regards,
    Taz
  5. #25
    May 2008
    Wow, that's actually kind of expensive. I pay about $100 shipped for the LS1 PCMs from S10s, but they come with with the engine and charging system wiring harness.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
  6. #26
    May 2008
    I was just thinking... Have you tried making a bench harness to rule out the possibility of something in the vehicle affecting the flashing? Did you save a log of when you tried to flash the PCM the first time?
    48 LB injectors
    T70 turbo.
  7. #27
    If it has remote start, remove/pull the fuses for the bypass and the main brain unit. They try it again, I dont have an issue with my remote start on my 02 but that 04 has one that with the aftermarket stereo wreaks havoc when trying to flash.
  8. #28
    May 2008
    Looks like it is not just you:
    http://forum.efilive.com/showthread....9-Dead-p10-pcm!!!
    48 LB injectors
    T70 turbo.
  9. #29
    Ok, this whole idea of needing to do a full flash to recover from a failed cal flash isn't justified, it's going to achieve nothing more than making you wait longer.
    I just test flashed two P10's here on the bench (because we don't have access to a Trailblazer).
    I used two different V2's with firmware v2.7.2 and 2.6.41, V7 software v7.5.6b136.
    The results are everything read and re-flashed fine. I stopped the reflash part way to simulate a failed flash and the recovery worked fine.
    If your P10 failed during the flash then you don't need another PCM, my experience is too many GM dealers don't understand how to make TIS do what they want so they just give up and say you need a new PCM.
    When you say it gets to 16K and stops that sounds like a classic case of something on the data bus interrupting the flash process. Though normally this would also cause problems on a read too.
    I am not sure what further tests I can do here so simulate your problem to come to a resolution when I can't duplicate the issue. Have you added any aftermarket audio equipment that is wired on to the databus? iPod adaptors and XM radio adaptors are notorious for causing such problems if they also monitor the vehicle data bus.
    I don't think you need a new PCM, but if for some reason you are going to buy one you shouldn't need to pay more than about $50 - $60. Make sure you get the right year model PCM too.
  10. #30
    Big D,
    Look at post #4 of this thread: showthread.php?14669-Dead-p10-pcm!!!
  1. Converted from man. to auto OS questions...
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: November 15th, 2008, 03:05 PM
  2. Replies: 8
    Last Post: January 19th, 2007, 07:29 AM
