Getting random defuels at WOT. Anyone have this problem before? I can post tune to if anyone wants to take a look at it.
What is your rpm limiter set at?
Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
EFI Live Cummins Beta Tester
Duramax and Cummins Tuning
423-506-7427
Which limiter? most of them are at 4000
Thanks,
Another log, truck will run strong then suddenly drop commanded fuel and slowly come back up.
levibencemod1.ctzTry this and see if it helps.
423-506-7427
Thanks bud, I,ll try this and post results.
Problem solved, it was the boost axis table. Thanks!
I just had the same issue with an 06 5.9 manual, so what did you actually change to cure this? I can post my tune.
2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
1984 CJ7 powered by a 2000 LS1. 4L60E.
2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
2003 Jetta TDI,
1986 K10 LQ4/4L80E
2003 Jetta TDI,
1986 K10 LQ4/4L80E
