Still trying to better grasp the parameters that need to be tweaked to get the PCM to accept the increase from 75 to 90mm. The application is based upon an F-body (non ETC). B4349 is in the file but looks geared for the ETC cars. I read some old posts regarding this and there seems to be some conflicts as to which direction to adjust this and not sure if it even effects the non ETC cars.
Does 4350 have any impact?
I would think that manually getting the throttle blade where it gets enough air in the motor and still keep IAC counts between 60-80 would be ideal.
I guess while we are on the subject we mind as well discuss the ETC cars as well.![]()
Howard
