Results 1 to 3 of 3
Thread: Can you go from C to F degrees?
    May 2006
    Default Can you go from C to F degrees?
    How do you change the units form C to F
    Jun 2005
    The yellow 'L' with the bullseye up top in the toolbar (see top left of attached pic). Sort by data units and then highlight all *C, right click, and under data value units, select imperial. Changes to Data Units are done in the Data value units menu, Col Units in the Column label units, and Row Units in the Row label units. Make sense?
    May 2006
    Quote Originally Posted by SSpdDmon
    What he said.
  1. 40 Degrees max timming, i want more
    By fezz57 in forum Gen III V8 Specific
    Last Post: November 5th, 2011, 08:36 PM
  2. Why always 10 Degrees at WOT
    By 1bar in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 6th, 2009, 01:56 PM
  3. Spark not advancing more that 17 degrees???
    By jeffpark_ in forum General (Petrol, Gas, Ethanol)
    Last Post: March 17th, 2009, 03:41 AM
  4. b7934 degrees
    By dynarex in forum Gen IV V8 Specific
    Last Post: February 17th, 2008, 03:30 PM
  5. Run Spark 50 degrees?
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2005, 01:00 AM
