Results 1 to 10 of 13
Thread: Hosting an Image
    Arrow Hosting an Image
    0. arrange Scan/Tune tool windows to show the point you want to make (make 2" smaller than the screen width);
    1. press PrintScreen or PrtScrn on your keyboard;
    2. paste into an image editor such as IrfanView or Greenshot;
    3. crop the image and add annotations as required (blur out VIN/serial/license numbers);
    4. save the image as a .png file;
    5. upload the image to an image hosting site such as ImageShack;
    6. the hosting site will give you a link to the image you uploaded, copy this link;
    7. on the thread reply toolbar click the Insert Image button, paste the link into the box, click Insert Image;
    8. finish typing your reply, and submit the reply.
    From image on public website (url):
    paste the url from your hosting website (e.g. ImageShack, PhotoBucket, etc).
    From Image on your PC:
Name:	Hosted Image.png
ID:	10933   Click image for larger version.
Name:	Host Image From Computer.png
    Arrow Attaching an Image
    If you want to post a non-image file, start at step 5 below.
    5. below the reply box click Go Advanced, scroll down a little, click Manage Attachments (see 1 in pic below);
    6. in Manage Attachment popup box click Add Files (see 2 in pic);
    7. in Upload Files popup box click Select Files (see 3) and locate file, select it, click OK, file appears in Upload Files popup box;
    8. click Upload Files (see 4), file appears in Attachments section of Manage Attachments popup box;
    9. click Done (see 5), file appears in Attachments section of the post;
    A. finishing typing your reply, and submit the reply.
    Or, follow the sequence in this pic:
Name:	Manage Attachments.png
    Default Newer forum software attachment instructions
    Summary of post #2:
    Go Advanced -> Manage Attachments -> Add Files -> Select Files,
    select the file(s) you want to upload, Open,
    Upload Files -> Done
    Also a quick tip for those using Windows 7, there is a neat little program called Snipping Tool. Click Start->All Programs->Accessories->Snipping Tool. (Alternatively you can press Start then type Snipping Tool.)
    Simply Click n Drag the area you wish to post online, it will then open a window that has your image. Click the save icon (or File->Save As), name it what you want, then upload it using Joe's above post.
    This program is great for capturing only part of a screen, you do not have to use MS Paint or Photoshop to try and remove parts you don't want to post online (like your VIN number at the bottom of the Scan Tool window).
    swingtan
    Guest
    And an additional tip if you do this a lot....
    "Greenshot" is a tool that the Windows "snipping tool" was probably taken from. The difference is that Greentool is open-sourced and runs as a background process in Windows. Just press the "Print Screen" button and you get the cross-hairs to select the screen section you want. Then it loads that section directly into a utility that allows you to edit and save the image, or just save it directly to a folder with no move actions needed.
    Simon.
    Interesting Simon, didnt know about Greenshot just about Snag-It which is very similar too. I might look into that, I like the snipping tool but if I dont have to start typing I wont!
    swingtan
    Guest
    Probably should have provided a link......
    http://sourceforge.net/projects/greenshot/
    Quote Originally Posted by swingtan View Post
    Thanks, very handy
    Updated posts #1 and #2 for the version 4 forum webapp (greenshot made it a snap).
    Default Attaching an image from your PC
    1. press PrintScreen or PrtScrn on your keyboard, or use Greenshot to capture an image of your screen;
    2. paste into an image editor such as IrfanView or use the Greenshot viewer/editor;
    5. Click the Image button (see 1 in pic below);
    6. Click the From Computer tab (see 2);
    7. Click Select Files (see 3);
    8. Select file (see 4) and click Open (see 5);
    9. Click Upload Files (see 6);
    10. Finish typing your reply and post it.
  1. Redline Motorsports hosting May 5th class!
    By Redline Motorsports in forum EFI University
    Last Post: April 12th, 2007, 02:36 PM
  2. First Post!
    By TAQuickness in forum FlashScan V1
    Last Post: January 4th, 2007, 08:40 PM
  3. First Post!
    By Redline Motorsports in forum Gen III V8 Specific
    Last Post: November 20th, 2006, 08:08 AM
