Results 1 to 10 of 13
Thread: Couple of basic Auto VE issues for guidance?
Hybrid View
    Oct 2003
    Default Couple of basic Auto VE issues for guidance?
    I have been around her since the beginning but just now being dragged kicking and screaming into Auto VE for bigger cam and displacement.
    Two questions after intitial logging.
    Started with stock 6.0 VE table which worked decent with MAFtune but now>
    I cannot sustain anything near idle either before initial log or after first cut.
    I suspect it is way too rich to hold any idle so I must diddle the throttle above ~1600rpm to keep it running. AFR is about 10 in the range below 1600. Can I just put in some guesstimate #s in that lower range to catch an idle so that Auto VE can work on it? ( I revived my old MAF tune for a sanity check and it idles ok)
    The tuning abouve 1600 seems to be leveling out fine.
    Can I or should I just use my new derived B0101 valves in the backup (2000 OS) B0103 or is there some good reason why those tables should be different?
    Thanks always,
    Bruce
    PowrMax Performance
    100 mm PowrMAF
    Jan 2005
    I switched to SD Custom OS3 on my 01 C5 with minimal mods, just to get a feel for the changes necessary, and even with a stock displacement engine/stock cam combination, idle calibration was way off, just switching from MAF to SD. I could never get Auto VE to give me the results I wanted, so I worked with wide band AFR data and made changes manually based on the logged data. But before I could get that far, I had to completely rework the VE table just to get a place to start. The VE tables for MAF and SD tunes look like they're for two different vehicles. Don't worry about what should be-- just give the engine what it wants and you should be able to establish a reasonable baseline fairly easily. Also, if you haven't already, jack up the ETC Predicted Airflow table (C6101) to avoid setting P1514 and a dead gas pedal.
    DigitalEFI- EFILive US Distributor
    [email protected]
    678/344-1590
    Oct 2003
    Quote Originally Posted by dfe1
    I just give the engine what it wants and you should be able to establish a reasonable baseline fairly easily. Also, if you haven't already, jack up the ETC Predicted Airflow table (C6101) to avoid setting P1514 and a dead gas pedal.
    Thanks, I got 1514 from the start so that is fixed.
    I will try to guess what it wants to baseline. Reaaly surprised the perscribed VE values are totally unrunable.
    PowrMax Performance
    100 mm PowrMAF
    Jan 2005
    If you are using a 98-00 OEM OS, you need to apply the changes to both the primary and back up VE tables. When in SD, for these OS's, the PCM is running off the back up VE table. The changes to the back up will effect your next drive, and the changes to the primary are setting the path for you to return to MAF operation and or upgrade to a more friendly OS.
    Quote Originally Posted by Bruce Melton
    Shouldn't be that shocking. The tutorial was written for a broad audience. On one end of the spectrum, there are folks such as yourself that wisely inquire to the why and proceed with caution. On the other end, there are folks that have not a clue as to what an Air Fuel Ratio is or how to avoid dangerously lean conditions.
    Perhaps if you took row 400-1600 and reduced the values by 5% increments (reduce, flash, reduce, flash, reduce, flash) that will get you idling again and able to fine tune.
    Oct 2003
    Quote Originally Posted by TAQuickness
    The tutorial sets up 2 BEN MAPS one for primary and one for backup. The stock VE tables are similiar for Primary and Backup. Is it reasonable to use the AutoTuned Primary results for backup?
    I should update OS but waiting for V2 I guess.
    PowrMax Performance
    100 mm PowrMAF
    Jan 2005
    You could do a copy paste with labels from the primary to secondary. But, teh resolution of the tables is different. I believe the primary is in 5 kPa increments while the back up is in 10 kPa increments.
    Prior to upgrading to an 02 OS, I had noticed minor differences in BEN's between the two maps.
    If you have any interest in upgrading your OS, I would do it now, to an 02 OS. Makes the initial VE tuning easier (no back up VE table), and opens up a lot of nice options in the custom OS segment. OS5 is bad to the bone.
    Oct 2003
    Wayne,
    The VE is coming along now, albeit slowly.
    Sent you an email,
    Bruce
    PowrMax Performance
    100 mm PowrMAF
  1. new to EFI Live need some guidance.
    By 6']['9 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2008, 03:03 PM
  2. Some guidance required!!!!
    By topfuelman in forum Gen III V8 Specific
    Last Post: June 11th, 2008, 04:40 PM
  3. Couple of Auto VE questions/observations
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: May 1st, 2007, 12:11 AM
  4. Idle issues after Auto VE tune
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: September 24th, 2006, 05:39 PM
  5. a couple idle issues here.
    By BACKinBLACK in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2006, 01:17 AM
