IMPORTANT
IF YOU HAVE NOT ALREADY DONE SO,
YOU MUST UPDATE FLASHSCAN'S BOOT BLOCK TO V2.05.08(0426)
BEFORE
YOU ATTEMPT TO UPGRADE THE FIRMWARE TO V2.05.16 OR LATER.
Under no circumstances should you attempt to use boot block V2.05.06 (released March 26, 2008).
See this link for more info on what is wrong with V2.05.06
http://forum.efilive.com/showthread.php?t=7804
Download here: http://download2.efilive.com/Softwar...ay_19_2008.zip (20Mb)
This download includes and supersedes all previous BBL beta downloads.
ALL *.pmm files have been updated. you MUST delete ALL *.pmm files from FlashScan (before upgrading the firmware) and from the folder: \Program Files\EFILive\V8\config (before unzipping the downloaded zip file). Failure to do so will cause unpredictable results when you restart FlashScan after updating the firmware to 2.05.17(0519).
The Readme_First.pdf file included in the zip file has not been updated, except to update version numbers.
The FlashScan AutoCal V2.5 Release Notes _beta_.pdf file has some important "Known Issues" asnd updates. Please read them.
The FlashScan AutoCal V2.5 Quick Reference _beta_.pdf file has not been updated.
Make sure you update your FlashScan (and/or AutoCal) firmware and boot block using the latest *.efw files from the \Program Files\EFILive\V8\Firmware folder.
