Page 1 of 11 123 ... LastLast
Results 1 to 10 of 102
Thread: TAQ Cables: Wideband to V2 Serial Cables
    Jan 2005
    Thumbs up TAQ Cables: Wideband to V2 Serial Cables
    These are plug-and-play cables enabling you to log your wideband O2 sensor via serial link to FlashScan V2. Learn more about the advantages of serial vs. analog WB logging.
    To order, visit: TAQCables
    The following wideband controllers are supported:
    TAQCable sLC1 (~ 3' [1m]) for Innovative LC-1*
    TAQCable sLC1e (12' [3.7m] extension) for Innovative LC-1
    TAQCable sLM2 (~ 4' [1.2m]) for Innovative LM-2
    TAQCable sTE (~ 3' [1m]) for TechEdge controllers
    Edit: I have dropped the sLM1 from the product line.
    *For sLC1 only, custom length cables, from 0.5' (0.15m) up to 12' (3.7m) available for an additional fee
    Jan 2005
    Arrow TAQ Cable - sLM2
    For reference, the PDF attachment contains the instructions for installing the sLM2 cable and validating the connection. Also attached is a photo of the sLM2 cable
    Jan 2005
    Default Serial vs. Analog?
    Serial communication has many benefits over analog:
    • Accuracy: Serial data is a digital transmission and is not as susceptible to interference as analog signals (i.e. no static. The data packet is either sent or it's not.)
    • Efficiency: Setting up V2 for serial communication takes less than 3 minutes and requires 0 maintenance. Analog configuration requires programming of the WB controller, calibration of the analog inputs, and, in some cases, configuring custom PID's to convert the analog input to AFR, lambda, or EQ ratio.
    • Real Estate: By utilizing V2's serial interface, you now have 1 or 2 more available analog inputs for logging other important stuff (i.e. fuel pressure, oil pressure, oil temp, N20 bottle pressure, etc…). Another good thing, especially for LM-2 users, you can eliminate the WB analog cable!
    • Perks: When utilizing one of the Innovative widebands, V2 can command the wideband controller to perform a free air calibration of the sensors. You can't do that via analog's.
    The attached screen shot demonstrates the difference between box-stock serial and analog data. What you are looking at:
    • Brand new dual channel LM-2 w/ new sensors. Updated to the latest LM-2 firmware and performed a free air calibration for both sensors - no other configuration was performed.
    • V2 was formatted and upgraded to firmware 20, followed the steps in the sLM2 instructions to setup V2 for serial communications - no other configuration was performed.
    From left to right, top to bottom: Serial Bank1, Analog Bank1, Serial Bank2, Analog Bank2. Theoretically, there should only be 2 visible traces in the chart. However, you can see there is a 0.3% - 3.7% variance between the respective serial and analog values.
    TAQ, generous cable length and good write up...
    Jan 2005
    Thanks Joe. That reminds me, cables are about 3 - 4 feet in length.
    Jan 2005
    Arrow TAQ Cable - sLM1
    For reference, the PDF attachment contains the instructions for installing the sLM1 cable and validating the connection. Also attached is a photo of the sLM1 cable
    Last edited by TAQuickness; September 4th, 2008 at 11:10 AM. Reason: Photos and Instructions Now Available!!!
    Jan 2005
    Arrow TAQ Cable - sLC1
    For reference, the PDF attachment contains the instructions for installing the sLC1 cable and validating the connection. Also attached is a photo of the sLC1 cable
    Last edited by TAQuickness; September 4th, 2008 at 11:09 AM. Reason: Photos and Instructions Now Available!!!
    For the price these are being sold for you just would not bother trying to make one yourself. Nice work.
    Oct 2003
    Ain't that the truth?
    And considering I will give you one free with a LM-2--
    PowrMax Performance
    100 mm PowrMAF
    Jan 2005
    All pm's replied. Thanks guys!
  1. WB to V2 Serial Cables
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: August 18th, 2011, 04:40 AM
  2. LM1 Serial Cables
    By TAQuickness in forum Lounge
    Last Post: August 18th, 2009, 04:32 AM
  3. V2 Cables
    By MMLMM in forum FlashScan V2
    Last Post: May 13th, 2009, 01:18 PM
  4. OBDII cables
    By limited cv8r in forum General
    Last Post: July 20th, 2007, 02:29 AM
  5. FlashScan & V2 Datalogger Cables
    By Brayden in forum General (Diesel)
    Last Post: June 7th, 2006, 11:46 AM
