Results 1 to 10 of 10
Thread: Weird problem with airflow spike causing temp power failure
    Oct 2005
    Default Weird problem with airflow spike causing temp power failure
    This has happened a few times, but as I wasnt logging at the time couldnt get to the bottom of it. I have messed around with Torque management and ETC airflow Diagnostic settings and I think its somewhat better.
    No MIL or DTC's are set but going over the log this am I found g/cyl spiked to 1.46g/cyl! which is well into FI territory and Im still setup stock NA. You can see the spike on the "79200" vertical bar. Fueling doubles which might be what the power loss is all about. Too rich to burn properly? Question is how to stop the spike? MAP is ok, which means airflow calc in SD should still be ok. VE looks all nice a smooth. RPM is reported ok etc.
    Does anyone have any thoughts on the matter?
    2008 Z06 C6 Corvette
    Mafless?
    Oct 2005
    Sorry yes, CLSD no LTFT's Stock LS2 with OTRCAI + RollerRockers
    Its at the end of this logfile http://www.systemsup2.plus.com/BBL00010.zip
    ok, simple fix.
    Open Virtual VE table, select entire table, add '1' to all cells.
    Generate coeffs, save file, flash.
    Le us know how it goes.
    Oct 2005
    I did think maybe something was weird in there and was going to hit the smooth button, but adding 1 all over sounds better. Ill give it a bash and report back.
    Redline Motorsports
    Guest
    What happened with this?
    Ther is a bug in the GM code that shoots to a incorrect zone , by adding 1 to every value in the VVE table EFILIVE recalculates the coefficients and corrects the bug.
    Oct 2005
    Yeah, one to watch out for
    So far so good, its not done it again, but you have to hit the right cell for it to trigger.
    As discussed I added 1 to all cells and recalculated values.
    Jul 2008
    Has anyone had this happen and seen the car go lean?
    Reason I ask, a mate of mine who has a VE has seen the AFR's go lean without any change to the tune.
    Cheers
    LS1VT209
    Quote Originally Posted by ls1vt209 View Post
    Cheers
    LS1VT209
    If you encounter the bug the injectors shut off completely and go very lean for a instant , the cure is easy , add 1 to the whole VE table and recalculate the co efficients.
    Only occurs mafless when there isnt a change to every zone
  1. Weird fan problem
    By johnsZ06 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 25th, 2008, 02:20 PM
  2. Weird fueling problem
    By FFP in forum Gen III V8 Specific
    Last Post: January 9th, 2008, 04:54 PM
  3. Wiiiiierd Problem...MAF causing trouble!!!
    By 01Blackerado in forum Gen III V8 Specific
    Last Post: October 2nd, 2007, 06:34 AM
  4. Weird Problem
    By FFP in forum Custom Operating Systems
    Last Post: December 21st, 2006, 01:32 AM
  5. Weird problem with AFR (LM-1)
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 14th, 2006, 12:55 AM
