Results 1 to 10 of 11
Thread: Timing mark's on Vortec 5.7
    Jul 2009
    Default Timing mark's on Vortec 5.7
    Howdy all,
    Me again!
    I have noticed a lack of excitement on my ECU supplier's behalf to help me any more than they have.
    So to this end i have decided as my back-up plan to replace the dizzy with a electronic style jobbie that they might be able to get right, thus eliminating my CAS as a problem.
    I was having a look under the car for the timing marks on the harmonic balancer/timing cover. and cannot find the one on the timing cover.
    Is it removeable? or is it cast into the plastic timing cover itself?
    I have been told that i have to line up the 2 line's on the pulley/timing cover and then the 2 line's in the dizzy will be lined up as well.......The one's on the timing cover being TDC on number1 and the one's in the dizzy being 'On the rock' on number 8, is this correct?
    Can anyone help me?
    Thank's in advance,
    Steve.
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by Vortec Patrol View Post
    Howdy all,
    Me again!
    Can anyone help me?
    Thank's in advance,
    Steve.
    there's a notch in the side of the balancer and one cast into the timing cover. the notch on the timing cover is at about 2 o'clock.
    you can kinda see them at the very bottom of this pic:
    Jan 2007
    Is there any reason you can't run the truck with an LS1 PCM?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Nov 2007
    I should have also mentioned that when those timing marks are ligned up, its EITHER TDC compression for #1 OR #6, have your valve covers off and go back and forth a little watching which valves move to determine which cylinder is at TDC, an extra 180* will bring the other cylinder to TDC.
    Jul 2009
    Quote Originally Posted by hquick View Post
    I dunno,.....is there?
    I have no idea about this engine hquick!, i would be wrapped if it was as easy as that!
    If so i have alot more question's on how to do that!
    Steve.
    Jul 2009
    Quote Originally Posted by Aloicious View Post
    Cheers Aloicious,
    Love the name!....it is my 'aka' name! 'Aloicious Wheelbarrow'
    No drama's! thank's for the pic! make's a heap of sense.
    I will pull the rocker cover off when i do it.........if i do it!
    No wonder i couldnt find it, it's in a bitch of a spot!
    Steve.
    Jul 2009
    Man......I am wrapped with this site!
    You bloke's on here are great! I have learnt more about my engine in the last week than in the 3 year's ive owned it for.
    Everyone on here has been great and very helpful, and this would be in the top 2 of the forum's i have registered too.
    Thank's again, your patience with a bloke like me that is a bit knowledge challenged with this engine, your help is fantastic.
    Steve.
    Nov 2007
    Cheers Aloicious,
    Steve.
    no problem, "Aloicious Jones" is the fake name I used to order pizza with as a kid. heh...
    Hquick is correct, you CAN run a LS1 PCM with your engine, both him and I are running a 2002 12200411 PCM on our L31 vortec 5.7's. here's some info on it if its something you're interested in:
    http://www.pacificp.com/forum/viewtopic.php?t=3240
    its a long thread but full of good info
    let us know if you have other questions.
    Sep 2009
    I noticed in your photo that there are no guide plates for the pushrods. How is that going to work?
    That rocker roller tip is designed to self-align on the valve tip, so guide plates are not needed.
  1. vortec v6 to vortec v8 swap
    By grezzmky in forum Vortec V6/V8 Specific
    Last Post: September 21st, 2009, 06:49 AM
  2. 1998 Vortec timing and fuel issues
    By KAZ MotorSports in forum Vortec V6/V8 Specific
    Last Post: May 26th, 2008, 07:01 PM
  3. ckp timing vortec 5.7
    By achidotcom in forum Vortec V6/V8 Specific
    Last Post: March 25th, 2008, 08:02 PM
  4. Timing for L31 Vortec
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: May 26th, 2007, 08:46 AM
  5. Mark Log Segment
    By Chevy366 in forum General
    Last Post: February 28th, 2007, 08:32 AM
