I installed a new pcm and was able to successfully do a CASE relearn. Now I am having start problems, as in not at all. It turns over & wants to crank but it is a no go. I've disabled the VATS & still nothing.
After scanning the PIDS, it seems that in the VTD there is something enabled with regards to the fuel system whereas everything else is either disabled or no in the field.
PRI CAPTION DESCRIPTION VALUE UNITS MIN AVG MAX PARAMETER SYSTEM
1 VTD-VTD1 Vehicle Theft Deterrent Fuel Cont No . No No No GM.VTD Fuel
1 VTD-VTD2 Vehicle Theft Deterrent Fuel System Enabled . Enabled Enabled Enabled GM.VTD Fuel <===HELP
1 VTD-VTD3 Fuel Disabled No . No No No GM.VTD Fuel
1 VTD-VTD4 Auto Learn Timer Not Active . Not Active Not Active Not Active GM.VTD Fuel
1 VTD-VTD5 VTD Fail Enable Not Active . Not Active Not Active Not Active GM.VTD Fuel
1 VTD-VTD6 Password Learning Disabled . Disabled Disabled Disabled GM.VTD Fuel
I've searched through some older threads & some have dealt with various codes like U1255, but didn't really have a clear post for resolution. It seemed it had it one day & the next few post all was resolved. :?
HELP! HELP! HELP!
