Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: January 31st 2011 pre-release (Updated Feb 03, 2011)
    Default January 31st 2011 pre-release (Updated Feb 03, 2011)
    This pre-release is beta software. We've tested it in controlled environments, however there may still be some minor issues. You should only update/use this pre-release in environments where failure can be tolerated and/or recovered using other processes.
    The V7.5 software is available here:
    http://download.efilive.com/Software....149_Setup.exe
    The V8 software is available here:
    http://download.efilive.com/Software....142_Setup.exe
    IMPORTANT: The new firmware is V2.07.05 which means you cannot go back to V2.07.04 once you have updated your firmware.
    The firmware update also requires that you update all script files (*.obj files) that exist on your FlashScan (or your customers' AutoCal) devices. Failure to update the script files will result in error $050B Script file not supported by current firmware version.
    The easiest way to update the script files on your devices is to:
    1. Connect your FlashScan or AutoCal device to the PC.
    2. Run the EFILive V8 Scan and Tune software.
    3. Select the F5: BBX option.
    4. Click on the [Read] button to read the current setup of the attached device.
    5. Click on the [Program] button which will cause all outdated files to be updated.
    It is not necessary to save the BBX Options file after performing the above procedure.
    This update contains fixes for most of the problems that have been reported in the previous pre-release software and firmware detailed here: http://forum.efilive.com/showthread....11-pre-release
    If you have reported a problem and discover that it has not been fixed in this pre-release, please create a support ticket explaining the problem in detail here: http://support.efilive.com/
    Updates available in this pre-release:
    • In EFILive_ScanAndTune V8 -> F3: Tune -> F4: Properties -> Calibration Information:
      • The "Author:" field can only be modified if its value is ".", once its value has been set to something other than "." it cannot be changed again.
      • A new field "ModifiedBy:" can be changed at any time to indicate who has made additional changes to the file.
      • The two date fields "Created:" and "Modified:" are now display-only. They cannot be updated manually by the user. The software sets the Created date when the file is first saved and updates the modified date each time the file is re-saved.
    • To help make switching between V7 and V8 easier, there is now a right-click menu option on the FlashScan System Tray icon to allow the user to disconnect the V8 software from FlashScan/AutoCal to allow the V7 software access to the USB device(s).
    • The V7 software now correctly identifies the device's authorization level and shows the calibration tables that are normally restricted when a device is not connected.
    • Calculated PIDs were not being evaluated in the correct order. That caused calculated PIDs that depended on the value of other calculated PIDs to lag by one or more frames. Calculated PIDs are now evaluated in PRN order, the lowest PRN is evaluated first.
    • Updated Cummins read/flash routines to clear diagnostic trouble codes when completed.
    • In EFILive_ScanAndTune V8 -> F3: Tune -> F4: Properties:
      Changed the way Content Management and Device Management options are presented to the user. Hopefully the new presentation makes it easier to understand.
    • If the user attempts to "Save" a file (i.e. overwriting the original) that has content or device management options activated for the first time, a warning is displayed explaining that it would be better to use "Save as..." to create a new version of the file. That way the original file will still exist without any content/device management options active.
    • Fixed problem when attempting to BBF an E60 (LLY Duramax) and if the controller was already licensed in pass-thru mode, then FlashScan did not recognize the controller as licensed.
    • Controller codes that have recently changed are now automatically updated in configuration files (i.e. Option.txt). Those controller name changes are:
      • LB7 -> E54
      • LLY -> E60
      • LBZ -> E35A
      • LMM -> E35B
      • LML -> E86
    Known issues for this pre-release (these will be addressed in a future update):
    • LS1A is not auto-identified, you must right click and select it prior to V8 pass-thru reading.
    • DMA PID's for the E39/E78 cannot be logged from V7 Scan direct, BBL is the only way to capture DMA PID's.
    • AutoCal auto-locking is only available for the E38 controller, other controllers will have AutoCal auto-locking implemented soon.
    As of Feb 01, 2011, the download files have been updated from
    http://download.efilive.com/Software....147_Setup.exe
    http://download.efilive.com/Software....140_Setup.exe
    to
    http://download.efilive.com/Software....148_Setup.exe
    http://download.efilive.com/Software....141_Setup.exe
    Changes in these two updates:
    V7.5.6.148
    • Added E37 VATs patch.
    • Fixed V1 Personal, Commercial and Workshop cables from being mis-identified as Scan Only, Workshop and Unknown respectively.
    • Fixed problem with loading *.ctd files created with V8.1.2.140
    V8.1.2.141
    • Internal component updates.
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Thanks again Paul
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Nov 2007
    No Firmware update (Feb 01) correct ?
    Funny how the V8 build number is catching up to the V7 build number.
    Quote Originally Posted by L31Sleeper View Post
    Correct.
    I was just thinking the same thing. A lot more work is going into V8 at the moment.
    Lifetime Member driver456's Avatar
    I did the updates and its telling me my Roadrunner is not licensed or something like that when I'm trying to flash the RR pcm...............Paul
    Quote Originally Posted by driver456 View Post
    Other customers have also reported this problem. It is being worked on now as a top priority.
    A patch should be available in about an hour.
    Due to a PC failure here, the RR license patch will not be available until tomorrow.
    Sorry, but I've been recovering/reinstalling software for the past 4 hours.
    Not a problem.We have alot of snow here and its snowing again,So its not like I'm going any where with it ....................Paul
    As of Feb 03, 2011, the download files have been updated to:
    V7.5.6.149
    • Fixed Tune Tool software not recognizing valid RR licenses.
    V8.1.2.142
    • Changed EFILive_ScanAndTune V8 -> F3: Tune -> F4: Properties
      so that only one panel may be expanded at a time.
    • Updated Cummins read/reflash options to clear DTCs.
  1. January 24th 2011 pre-release
    Last Post: April 10th, 2011, 04:17 AM
  2. January 2011 update
    By GMPX in forum Cummins 5.9L
    Last Post: January 15th, 2011, 07:28 PM
  3. Pre release 7.5.1
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2007, 08:55 PM
  4. V7.2.1 pre-release is publicly available
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: May 8th, 2005, 02:29 PM
  5. V7.1.9 Pre-release is now available
    Last Post: April 13th, 2005, 02:47 PM
