Results 1 to 7 of 7
Thread: 4L60E Manual convertor lock up switch.
    Member Laychut's Avatar
    Jan 2011
    Default 4L60E Manual convertor lock up switch.
    Hi,
    I have seen Manual convertor lock up kits for auto transmissions in Toyota and Nissan 4wds. The purpose is to lock up the convertor in low gear while desending downhill, which in turn saves burning or wearing out your brakes.
    I have fitted a GenIII 5.7 engine and 4L60E transmission out of a 2005 VZ Calais to my HJ60 land crusier. I was wondering if any one has fitted a convertor lockup kit to a 4L60E? Is it possible?
    If I interrupt the wire from the ECU that controls the convertor lock up and run it through a change over relay that would be controlled by a remote switch, would this work? I am pretty sure the ECU signal is an earth, so the relay would just change the ecu signal for another earth.
    Any feedback or ideas?
    Lifetime Member Gregs's Avatar
    Sep 2008
    i was actually just wondering about the same thing the other day
    03 Silverado 5.3 ECSB 4x4 Z71
    Intake, Exhaust, LC-1, Vette Servo
    Pro Comp 285/75/16 tires, 3" Body Lift
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    Dec 2008
    Yes the signal is earth, but I'm pretty sure that it is impossible to lock it in low (hydraulics prevent it).
    You don't really need a relay and you don't need to cut the ECU's lock signal wire...
    You wire the switch in parallel with the ECU (i.e. between the TCC lock signal wire and ground), so either the switch or the ECU can lock the TCC.
    When the switch is open (floating), the ECU is free to lock the TCC (by connecting to ground).
    When the switch is closed (connecting to ground), the TCC is locked regardless of ECU lock signal (floating)...
    [ this is same method as is done for coolant fan override switch ]
    [ hmmm, I wonder if ECU might throw a DTC for shorted TCC lock signal wire ]
    Jan 2011
    Hi Joecar,
    your thought is correct! I came across a fault finding manual that said that a DTC would be active for a short or an open wire.
    This got me thinking.....If I had the signal from the ECU sent through a relay coil while I was manually activating the TCC would it fool the ECU? I i ensured that the ohms resistance was the same as the coil for the TCC solenoid I should be ok.
    What do you think?
    I still have to look into Slow67's comment about the hydraulics preventing the TCC from activating in low gear. He could be right! Then I would be wasting my time pursuing this option.
    Look at HMTG page 54B (Overdrive Range - First Gear), see 5a, 5b, 5c...
    I see AFL feeding the TCC PWM solenoid, and I don't see anything to inhibit the TCC On/Off solenoid (other than it's command signal).
    Aug 2013
    gday just wondering if any one has had sucsess with this switch set up
  1. How to switch from 4l60e to a manual TH400 - 2003 corvette
    By Tracyrr in forum Gen III V8 Specific
    Last Post: August 18th, 2011, 07:59 AM
  2. How do I lock a 4l60E in 3rd on the dyno?
    By PRAY in forum Gen III V8 Specific
    Last Post: January 3rd, 2009, 02:39 PM
  3. 4L60E Manual Mode Downshifting 3-2 & 2-1
    By TRANNYMAN in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 3rd, 2008, 08:11 AM
  4. 411 5.7 vortec swap switch to manual tranny
    By jomobco in forum Vortec V6/V8 Specific
    Last Post: January 11th, 2008, 01:45 PM
  5. Torque Convertor?
    By Bradazz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 7th, 2006, 03:10 PM
