Guys,
I really need some help with this one. The pcm is going into reduced engine power mode during fast changes in airflow. For example, if your in the burn out box and modulating the throttle by bliping, then it will throw the code. It only happens when it is a large or sudden change like when the tires break loose. 5th gear pulls above 512 grams/s seem ok, 4th gear pull when the tires are spinning and above 511 grams/s it will do it.
So my question is this airflow tune related (scale VE and IPW) or the physical throttle body (thinking blade is stuck).
