Results 1 to 8 of 8
Thread: November 2016: EFILive Beta Test Release
    Default November 2016: EFILive Beta Test Release
    ATTENTION - BETA SOFTWARE RELEASE:
    The EFILive beta software is available to all users. We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. If you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends that beta testers use a separate FlashScan V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    IMPORTANT:
    During the beta test phase, the EFILive software and firmware version numbers have been updated multiple times as follows:
    1. Version 7.5 software: V7.5.7 to V7.5.8 and again to V7.5.9.
    2. Version 8 software: V8.2.2 to V8.2.3 and again to V8.2.4.
    3. Firmware: V2.07.104 to V2.07.105 and again to V2.07.106
    Those version number changes reflect two major compatibility updates:
    • The *.ctz and *.coz tune files' internal formats have been updated.
      Any tune file saved with one version cannot be opened using a previous version.
      A tune file saved with a previous version can be opened with a later version.
      For the purpose of determining tune file compatibility, the third digit of the software version number is used.
    • The *.obj read/flash script files have been updated. If you create a *.bbx quick setup file for your customers' AutoCal devices using this software and firmware version, then you must ensure that the users' AutoCal devices are also using this software and firmware version.
    Release Notes:
    Key Features:
    • 2017 Cummins support.
    • Controller Authorization to manage heightened security protocols for 2017 GM controllers.
    • The first release of 2017 GM vehicle support including updated E92 Corvette and E82 ECM for LGX 3.6L V6.
    • Changes to Remote Linking/Unlinking of AutoCal.
    • Updated documentation to support recently added features.
    Please note, with many new OS's released for 2017 models over several different ECM types, unsupported OS's may take some time to be completed and may not be currently supported in this release.
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.9 Build 313 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.4 Build 307 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.106 (Oct 27, 2016)To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue 1:
    Workaround:
    None.
    Issue 2:
    Workaround:
    Nov 2005
    Paul, any chance you could add a check box to "do not show this again" on the "Beta software warning"?
    Or maybe just have it pop up only every 5-instances of opening the program? Or just a "BETA" splash screen that pops up for a second and self-clears?
    12.9s @ 108 mph
    many thanks to Ross and Paul
    I don't mind this (say about 3 seconds worth):
    EFILive Distributor Trippin's Avatar
    May 2004
    Yes please. One or the other.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    I do plan on adding an option to allow a checkbox to disable the warnings (even I'm getting annoyed by them). Meanwhile you can stop the warnings like this:
    For V7 Scan and Tune, add a new entry in the registry like this:
    For V8, add a new section and key in the file \My Documents\EFILive\V8\Config\EFILiveScanAndTune.ini :
    Jul 2003
    I AM NOT THE ONLY ONE!!!!!!! jajaja...
    LOL
    The beta version has been promoted to "Release Candidate 1", available here: https://forum.efilive.com/showthread...se-Candidate-1
  1. September 2016: EFILive Beta Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: October 18th, 2016, 08:53 AM
  2. July 2016: EFILive Beta Test Release
    Last Post: September 5th, 2016, 03:18 PM
  3. May 2016: EFILive Beta 3 Test Release
    Last Post: June 6th, 2016, 07:30 PM
  4. April 2016: EFILive Beta 2 Test Release
    Last Post: April 30th, 2016, 08:49 AM
  5. April 2016: EFILive Beta Test Release
    Last Post: April 9th, 2016, 03:46 PM
